RG-S6920-4C Switches - 1
RG-S6920-4C Switches - 2
RG-S6920-4C Switches - 3
RG-S6920-4C Switches - 4
RG-S6920-4C Switches - 5
RG-S6920-4C Switches - 6
RG-S6920-4C Switches - 7
RG-S6920-4C – Next-Generation Data Center 100GE Switch with 100GE/400GE Line Cards
Compared with the traditional networking with modular core switches, the entire network with RG-S6920-4C switches uses the Clos architecture, reducing the TCO by 25% and power consumption by 31%. Furthermore, RG-S6920-4C switches help build stable and lossless networks.
  • Diverse ports, four service slots, up to 128 × 100GE ports or 32 × 400GE QSFP-DD ports
  • Highly-efficient heat dissipation and energy saving, with power consumption less than 1950 W and power conversion efficiency up to 94%
Key Specification View More
Data Center 100GE Core Switch RG-S6920-4C
Four service slots, with 100GE and 400GE line cards, allowing for easy expansion and satisfying future bandwidth expansion needs
Various ports, up to 128 × 100GE ports or 32 × 400GE QSFP-DD ports., which are fit for different scenarios of data center networks
Power modules in 2+2 redundancy mode, failover in seconds, and power module replacement without
network interruption, providing double protection for links
and Zero Packet Loss
RG-S6920-4C
100GE/400GE ports
Expansion Module Slots
Four expansion module slots, each supporting the line card with up to 128 × 100GE ports or 32 × 400GE QSFP-DD ports.
Expansion Modules
Four power modules
Six fan modules
Management Port
One management port, one console port, and one USB port, compliant with the USB2.0 standard
Switching Capacity
25.6 Tbps
Packet Forwarding Rate
8,000 Mpps
802.1Q VLAN
(W × D × H)
442 mm x 735 mm x 173.6 mm (17.40 in. x 28.94 in. x 6.83 in., 4 RU)
34.25 kg (75.51 lbs., including all line cards, power modules, and fans)
Maximum Power Consumption
● Max: 1,950 W
● Typical: 1,469 W
● Static: 516 W
AC
RG-PA1200I-F
● Rated voltage: 110 V AC/220 V AC
● Rated voltage range: 100 V AC to 240 V AC, 50 Hz to 60 Hz
● Max voltage range: 90 V AC to 264 V AC, 47 Hz to 63 Hz
High-Voltage DC
Input voltage range: 180 V DC to 300 V DC
Operating Temperature
0ºC to 40ºC (32ºF to 104ºF)
–40 °C to +70 °C (–40 °F to +158 °F)
Operating Humidity
10% RH to 90% RH (Non-condensing)
5% to 95% RH (non-condensing)
Operating altitude: up to 5,000 m (16,404.20 ft.)
Storage altitude: up to 5,000 m (16,404.20 ft.)
RG-S6920-4C
Layer 2 Protocols
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, jumbo frame (9 KB), IEEE802.1ad (QinQ and selective QinQ), GVRP
Layer 3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM routing, PBR, routing policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, DVMRP, PIM-SSM/SM/DM, MSDP, Any-RP
IPv6 Protocols
Neighbor discovery, ICMPv6, path MTU discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMP v6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, IPv6 QoS
IPv6 Features
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, manual tunnel and IPv4 over IPv6 tunnel
Data Center Features
PFC and ECN
M-LAG
RDMA
OpenFlow 1.3
BGP-EVPN
* AI ECN
* ECN Overlay
Global load balancing technologies such as RALB and AILB
Visualization
INT
Standard IP-based ACL, extended MAC-based ACL, extended IP-bsaed ACL, expert-level ACL, ACL 80, IPv6 ACL, ingress/egress ACL, ACL logging, ACL counter (ingress and egress counters are supported in interface or global configuration mode), ACL re-marking, global ACL, ACL-based redirection, displaying ACL resources, processing first facket of TCP handshake when binding the ACL to restrict SIP, matching 5-tuple of pass-by VXLAN inner IP packets against the ACL, matching the IP flag and DSCP fields of VXLAN inner packets against the expert-level ACL
802.1p, DSCP, and ToS mapping
Priority marking/remarking
High Availability Design
GR for RIP/OSPF/BGP, BFD, DLDP, REUP, Rapid Link Detection Protocol (RLDP), 2+2 power redundancy, fan redundancy, and hot swappable line cards and power modules
Security Features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), DDoS attack defense, unauthorized packet detection, data encryption, source IP spoofing defense, IP scanning defense, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, uRPF, broadcast packet suppression, DHCP snooping, ARP spoofing defense, ARP check, and hierarchical user management
Management Mode
SNMP v1/v2c/v3, Telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, overheat alarm, and configuration rollback
Other Protocols
DHCP client, DHCP relay, DHCP server, DNS client, UDP relay, proxy ARP, and syslog
Specification
RG-S6920-4C
Safety
● IEC 62368-1
● EN 62368-1
● EN IEC 62368-1
● BS EN IEC 62368-1
● UL 62368-1
● CSA C22.2#62368-1
● GB 4943.1
● EN 55032
● EN 55035
● EN IEC 61000-3-2
● EN IEC 61000-3-3
● EN 61000-3-3
● ETSI EN 300 386
● EN 300 386
● ICES-003 Issue 7
● ICES-003 Issue 6
● ANSI C63.4-2014
● FCC CFR Title 47, Part 15, Subpart B
● AS/NZS CISPR 32
● CISPR 32
● GB/T 9254.1
● 2011/65/EU EN 50581
● 2012/19/EU EN 50419
● (EC) No.1907/2006
● GB/T 26572
RG-S6920-4C
Four expansion slots, four power module slots, and six fan module slots
RG-PA1200I-F
Hot swappable power module, 2+2 redundancy, and front-to-rear airflow
M2EFAN I-F
Hot swappable fan module, 5+1 redundancy, and front-to-rear airflow
Expansion Modules
M6900-32CQ
Line card with 32 x 40GE/100GE QSFP28 ports
M6900-16CQ4QC
Line card with 16 x 100GE QSFP28 ports and 4 x 400GE QSFP-DD ports
M6900-08QC
Line card with 8 x 400G QSFP-DD ports
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
400G-QDD-SR8-MM850
400G SR8 transceiver, QSFP-DD form factor, MPO-16 APC, 850 nm, 100 m (328.08 ft.) over MMF
400G-QDD-AOCxM
400G AOC cable, QSFP-DD form factor, X=3 m/5 m/10 m/15 m/20 m /30 m/50 m
200GBASE Series Optical Transceivers
200G-Q56-SR4-MM850(D)
200G SR4 transceiver, QSFP56 form factor, MPO-12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MMF, in compliance with CMIS
100G AOC cable, QSFP28 form factor, 10 m (32.81 ft.)
40GBASE Series Optical Modules
40G SR transceiver, QSFP+ form factor, MPO, 150 m (492.13 ft.) over MMF
40G AOC cable, QSFP+ form factor, 30 m (98.43 ft.)
