RG-S5310-24GT4XS-P-E Switches - 1
RG-S5310-24GT4XS-P-E Switches - 2
RG-S5310-24GT4XS-P-E Switches - 3
RG-S5310-24GT4XS-P-E Switches - 4
RG-S5310-24GT4XS-P-E Switches - 5
RG-S5310-24GT4XS-P-E Switches - 6
RG-S5310-24GT4XS-P-E Switches - 7
RG-S5310-24GT4XS-P-E Switches - 8
RG-S5310-24GT4XS-P-E Switches - 9
RG-S5310-24GT4XS-P-E Switches - 10
RG-S5310-24GT4XS-P-E 24-Port GE Layer 3 Managed Access Switch with PoE+, 4-Port 10GE Uplink
  • Rich port types, 24 x 10/100/1000BASE-T ports, PoE/PoE+ supported, 4 x 1GE/10GE SFP+ ports for uplink
Key Specification View More
System switching capacity
154 Gbps
System packet forwarding rate
115 Mpps
65 W (without PoE load)
810 W (full PoE load)
Flash Memory
2GB
0°C to 45°C (32°F to 113°F)
Warranty duration
3 years
Layer 3 Access Switch for 10G Uplink RG-S5310-24GT4XS-P-E
24 x 10/100/1000BASE-T ports, PoE/PoE+ supported, providing high-speed network experience for short-distance services
The switch automatically detects and supplies the required power for powered devices, providing up to 15.4 W for IEEE 802.3af-compliant devices, or up to 30 W for IEEE 802.3at-compliant devices, meeting the requirements of common PoE applications such as security surveillance, teleconferencing, and wireless coverage.
achieving automatic O&M.
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-S5310-48GT4XS-P-E
24 x 1GE SPF ports
48 x 1GE SPF ports
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
115 Mpps
158 Mpps
115 Mpps
158 Mpps
115 Mpps
158 Mpps
154 Gbps
211 Gbps
154 Gbps
211 Gbps
154 Gbps
211 Gbps
3 MB
32,000
4,000/16,000 (authorized)
ND table size
2,000/8,000 (authorized)
8,000/12,000 (authorized)
2,500
1,200
Ingress: 3,500
Egress: 1,500
Number of IGMP groups
2,500
Number of MLD groups
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
4.0 kg
(8.82 lbs)
4.3 kg
(9.48 lbs)
4.2 kg
(9.26 lbs)
4.5 kg
(9.92 lbs)
4.3 kg
(9.48 lbs)
4.6 kg
(10.14 lbs)
6.20 kg (13.67 lbs)
6.50 kg (14.33 lbs)
6.38 kg (14.07 lbs)
6.58 kg (14.51 lbs)
6.78 kg (14.95 lbs)
6.69 kg (14.75 lbs)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-PA150IB-F (AC input)
RG-PD150IB-F (DC input):
RG-PA70IB (AC input):
● Maximum input current: 2 A
RG-PA70IB: 70 W
RG-PD150IB-F: 150 W
RG-PD150IB-F: 150 W
55 W
85 W
108 W
75 W (without PoE load)
1,570 W (full PoE load)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
27°C (80.6°F): 34.3 dB
45°C (113°F): 56.5 dB
27°C (80.6°F): 40.8 dB
45°C (113°F): 52.4 dB
27°C (80.6°F): 38.9 dB
45°C (113°F): 53.7 dB
27°C (80.6°F): 51.6 dB
45°C (113°F): 57.4 dB
45°C (113°F): 58.3 dB
Air discharge: 8 kV
Contact discharge: 6 kV
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-S5310-E Series
Ethernet Switching
Super VLAN and private VLAN
Basic QinQ and selective QinQ
Auto errdisable recovery
BPDU filter
Port fast
Root guard
MAC address filtering
GRE tunnel
IP Routing
IPv4 and IPv6 static routing
OSPFv2, OSPFv3, and GR
IPv4/IPv6 PBR
IGMPv1/v2 snooping
MLDv1/v2 and MLD proxy
MLDv1/v2 snooping
Global IP-MAC binding
MAB authentication
Basic LACP
Inter-VSU AP
Hot swapping of power modules
Local and remote stacking
SPAN, RSPAN and ERSPAN
SNTP
CLI (Telnet/Console)
SNMP v1/v2/c3
Web
Syslog/Debug
MACC
VXLAN (authorized)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
Power Module
RG-PA70IB
70 W AC power module
RG-PD150IB-F
150W DC power module
License
RG-VXLAN-MPLS-ENTRY-LIC
Optical Transceivers
What does the letter E in RG-S5310-24GT4XS-E mean?
E in the model name means that this is an enhanced model in this series.
118
What power modules should I buy for an RG-S5310-E series GE switch?
When selecting a power module, the first thing is to check the power consumption of the switch. If dual power modules are used for power redundancy, the power of a single power module must be greater than the power consumption of the switch. Taking the RG-S5310-24GT4XS-E switch as an example, the power consumption is ≤ 40W. You can purchase the RG-PA70IB power module for this switch.
Below lists some power module models and their description:
RG-PA70IB: 70W AC power module
RG-PA150IB-F: 150W AC power module
RG-PD150IB-F: 150W DC power module
RG-PA600I-P-F: 600W AC power module, PoE supported
RG-PA1000I-P-F: 1000W AC power module, PoE supported
170
How is loop detection realized in this series?
This series adopts the Rapid Link Detection Protocol (RLDP), a link detection protocol independently developed by Ruijie Networks for rapid detection of Ethernet link failures.
Most Ethernet link detection mechanisms detect link connectivity through auto negotiation of the physical layer based on the state of the physical connection.
However, this type of link detection mechanism has certain limitations. In some cases, it cannot provide users with reliable link detection information. For example, when the Tx and Rx ends of a fiber optic cable are incorrectly connected to an optical port, due to the existence of an optical fiber converter, the link on the port is still physically up, but in fact communication on the layer 2 link is off. Another example is that if there is an intermediate network between two Ethernet devices, due to the existence of a relay device on the network, the same problem will occur if the relay device fails.
With RLDP, users can easily and quickly detect a link failure on an Ethernet device, including unidirectional, bidirectional, and loop link failures.
291
加载失败
TOP
