RG-AP880-AR Dispositivos Wireless - 1
RG-AP880-AR Dispositivos Wireless - 2
RG-AP880-AR Dispositivos Wireless - 3
RG-AP880-AR Dispositivos Wireless - 4
RG-AP880-AR Dispositivos Wireless - 5
RG-AP880-AR Dispositivos Wireless - 6
RG-AP880-AR Dispositivos Wireless - 7
RG-AP880-AR Dispositivos Wireless - 8
RG-AP880-AR Dispositivos Wireless - 9
RG-AP880-AR Dispositivos Wireless - 10
RG-AP880-AR Dispositivos Wireless - 11
RG-AP880-AR, Wi-Fi 6 Quad-Radio 7.780 Gbps High-Density Indoor Access Point, 5Gbps Combo SFP Port
  • Upgraded to Wi-Fi 6, a combined data rate of up to 7.780 Gbps
  • Al radio for intelligent guidance of STA roaming, ensuring service continuity
  • Independent Al Radio for security protection, delivering better experiences and higher security
Key Specification View More
Wireless Protocols
802.11a/b/g/n/ac/ax
Radio Design
Quad-radio: 2.4 GHz (2×2), 5 GHz (2×2 and 4×4),
2.4 GHz/5 GHz (2×2), up to 10 spatial streams
7.780 Gbps
Antenna Type
Built-in smart antenna
Fixed Service Port
1 x 5GE SFP/RJ45 combo port, 1 x 10/100/1000BASE-T port
Bluetooth 5.1
Input Power Supply
54 V DC/1.1 A power supply
PoE/PoE+/PoE++ (802.3af/at/bt-compliant)
Max. Power Consumption
External Power Supply
Operating Temperature
–10°C to +50°C (14°F to 122°F)
IP Rating
230 mm × 230 mm × 51 mm (9.06 in. × 9.06 in. × 2.01 in.)
Wall/Ceiling mounting
3 Years
Wi-Fi 6 High-Density Indoor AR Series AP
RG-AP880-AR
Maximum Data Rate
7.780 Gbps
All-Optical i-Share+
Solution
Independent AI Radio
10 Spatial Streams
Bluetooth 5.1
5G Optical Port and 5G Electrical
Port for Flexible Networking
One 5G optical port supports higher bandwidth. With Ruijie All-Optical i-Share+ Solution, this port helps achieve all-optical gigabit access in rooms.
Upgraded to Wi-Fi 6
Achieving a Combined Data Rate of Up to 7.780 Gbps
High Concurrency
Low Latency
latency is as low as 20 ms.
High Security
High Speed
With 1024-QAM modulation, the
data transmission rate is 25%
higher than 802.11ac.
Al Radio for Intelligent Guidance of STA
Roaming, Ensuring Service Continuity
The built-in Al Radio independently scans STA status, and reports the scanning result of neighbor APs to ACs. The ACs then guide STAs to quickly access an AP with better signals.
In this way, STAs can maintain a good signal quality during movement, thereby achieving low latency, no lagging, and service continuity in roaming.
Traditional Settled AP
Average roaming latency: 300ms
Packet loss rate: 2%
RG-AP880-AR
Average roaming latency: < 30ms
Packet loss rate: < 0.5%
Different from traditional, periodic, single-radio scanning with blind spots, AI Radio performs independent, real-time, full-radio, secure scanning.
The secure scanning does not occupy communication radio resources or affect wireless performance, ensuring good network experiences.
AI Radio
Traditional AP
24/7 real-time scanning
5G/2.4G full-radio scanning
Legend:
Secure scanning
Data transmission
Scanning, Safeguarding
secure scanning.
AI Radio
Traditional AP
Unified Cloud Management
Go to WIS ->
Cloud O&M
24h Network Optimization
Real-Time Warning
Fault Locating
RG-AP880-AR
Ten spatial streams
● Radio 1 – 2.4 GHz: 2x2 MIMO, two spatial streams
● Radio 2 – 5 GHz: 2x2 MIMO, two spatial streams
● Radio 3 – 5 GHz: 4x4 MIMO, four spatial streams
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 1 – 2.4 GHz: 20 MHz and 40 MHz
● Radio 2 – 5 GHz: 20 MHz and 40 MHz
● Radio 3 – 5 GHz: 20 MHz and 40 MHz
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: 20 MHz and 40 MHz
Combined peak data rate: 1.200 Gbps
● Radio 1 – 2.4 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15 )
● Radio 2 – 5 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15)
● Radio 3 – 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: AI Radio for scanning only
Eight spatial streams
● Radio 2 – 5 GHz: 2x2 MU-MIMO, two spatial streams
● Radio 3 – 5 GHz: 4x4 MU-MIMO, four spatial streams
● Radio 4 – AI Radio, 5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 2 – 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
● Radio 3 – 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
● Radio 4 – AI Radio, 5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 5.200 Gbps
● Radio 2 – 5 GHz: 6.5 Mbps to 1.733 Gbps (MCS0 to MCS9)
● Radio 3 – 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
● Radio 4 – AI Radio, 5 GHz: AI Radio for scanning only
● Radio 3 – 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
Channels:
Combined peak data rate: 7.780 Gbps:
● Radio 3 – 5 GHz: 7.3 Mbps to 4.804 Gbps (MCS0 to MCS11)
● 2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 5.5 dBi.
● 5 GHz: six built-in omnidirectional smart antennas, with peak antenna gain of 7 dBi.
One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 3 dBi.
1 x 100/1000/2.5G/5GBASE-T port, in compliant with IEEE 802.3af/at/bt standard (PoE/PoE+/PoE++)
1 x 10/100/1000BASE-T port,supplying 48 V/12.95 W power to an IoT unit
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 1.0 kg (2.20 lbs)
Shipping: 1.25 kg (2.76 lbs)
● DC power: 40 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (5 GHz) 4x4, Radio 4 (AI Radio) 2x2, LAN 2 for PoE supply (48 V/12.95 W), and USB port for power supply (5 V/5 W)
● 802.3bt (PoE++): 40 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (5 GHz) 4x4, Radio 4 (AI Radio) 2x2, LAN 2 for PoE supply (48 V/12.95 W), and USB port for power supply (5 V/5 W)
● 802.3at (PoE+): 25 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (5 GHz) 2x2, Radio 4 (AI Radio) 2x2, LAN 2 supports data transmission but does not provide PoE output. The USB port is disabled and does not supply power to external devices.
● 802.3af (PoE): 12.2 W, Radio 1 (2.4 GHz) 1x1, Radio 2 (5 GHz) 1x1, Radio 3 (5 GHz) 1x1, Radio 4 (AI Radio) is disabled, LAN 2 supports data transmission but does not provide PoE output. The USB port is disabled and does not supply power to external devices.
● Idle mode: 12.2 W
External power supply
Note: At an altitude in the range of 3,000–5,000 m (9842.52–16,404.20 ft.), every time the altitude increases by 166 m (544.62 ft.), the maximum temperature decreases by 1°C (1.8°F).
512 MB DRAM, 256 MB flash
RG-AP880-AR
24 dBm
–96 dBm
24 dBm
–93 dBm
–90 dBm
22 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
–58 dBm
24 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
–88 dBm
18.5 dBm
–63 dBm
24 dBm
18.5 dBm
24 dBm
18.5 dBm
–57 dBm
24 dBm
–58 dBm
24 dBm
24 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
24 dBm
–50 dBm
Basic Functions
RG-AP880-AR
RGOS11.9(6)W1B2 or later
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
PSK and web-based authentication
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES), WPA3-Enterprise, WPA3-Personal
MAC address table size: 2,048
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Interface-based VLAN
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
Identification of IP address conflicts between downlink users
Number of IPv4 addresses set for each Layer 3 interface: 200
NAT, FTP ALG and DNS ALG
Number of IPv6 addresses set for each Layer 3 interface: 400
NTP server and NTP client
SNMPv1/v2C/v3
When the AP works in cloud mode, it can be managed through Ruijie Cloud.
RG-AP880-AR
Big data capabilities
RG-AP880-AR
RG-AP880-AR
Quad-radio, ten spatial streams, peak data rate of 7.780 Gbps
● Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 574 Mbps
● Radio 3: 5 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 4.804 Gbps
● Radio 4 (AI Radio): 2.4 GHz/5 GHz: two spatial streams, 2x2 MIMO, for scanning only
What are the differences between fat and fit modes of APs?
Fit APs are often deployed in environments with high requirements. To enable authentication, fit APs need to be used with authentication servers or authentication-capable switches.
Suitable for large-scale wireless deployment scenarios, fit APs need to work with ACs. ACs can deliver configurations to fit APs that are unable to implement configurations independently. In contrast, fat APs can function properly without ACs.
1451
How does the AP achieve flexible switching between fat and fit modes?
When the AP works in fit mode, it can be switched to fat mode through the AC.
When the AP works in fat mode, it can be switched to fit mode through the local console port or Telnet.
1440
What is the coverage radius of the AP?
Recommended coverage radius: 10 to 15 meters for indoor APs; 5 to 10 meters for wall-plate or i-Share micro APs; over 50 meters for outdoor omnidirectional APs; over 100 meters for outdoor directional APs.
The wireless experience depends on multiple factors, including the actual installation environment, the number of clients, wireless traffic, and interference. The preceding coverage radius is provided for reference only.
1621
加载失败
TOP
