RG-MAP920-SF-M Dispositivos Wireless - 1
RG-MAP920-SF-M Dispositivos Wireless - 2
RG-MAP920-SF-M Dispositivos Wireless - 3
RG-MAP920-SF-M Dispositivos Wireless - 4
RG-MAP920-SF-M Dispositivos Wireless - 5
RG-MAP920-SF-M Dispositivos Wireless - 6
RG-MAP920-SF-M, Simplified Optical Ethernet (SOE) Advanced Micro AP, Wi-Fi 7 Dual-Radio 3.570 Gbps
  • Long-range optical communication via flexible CWDM / hybrid cables
  • 2.5GE SFP port, delivering high bandwidth
Key Specification View More
Wireless protocol
802.11n/ac/ax/be
Dual-radio: 2.4 GHz (2x2), 5 GHz (2x2), up to 4 spatial streams
Max. data transmission rate
3.570 Gbps
Wi-Fi antenna
Built-in omnidirectional smart antennas
1 x 2.5GE SFP port
4 x 10/100/1000BASE-T ports
Bluetooth 5.3
256 (128 STAs per radio)
48 V DC/0.35 A power input over DC connector;
PoE/PoE+ input, in compliance with IEEE 802.3af/at
Max. power consumption
16.8 W
–10°C to +40°C (14°F to 104°F)
Dimensions (W x H x D)
86 mm x 160 mm x 35 mm
86 mm junction box or wall
RG-MAP920-SF-M, Wi-Fi 7 Micro AP for Simplified Optical Ethernet Solution
The Ruijie RG-MAP920-SF-M is a Wi-Fi 7 dual-radio optical micro access point (AP), for Ruijie Simplified Optical Ethernet (SOE) Solution in indoor scenarios of various sectors covering higher education, government, general education, finance, and business. It works with the master AP to realize high-bandwidth data transmission and long-distance PoE power supply through a hybrid cable.
Seamless Upgrade to Wi-Fi 7
2 x higher peak throughput
2.5GE SFP Port, Delivering High Bandwidth
2.5GE SFP port greatly improve the data transmission rate, coping with bandwidth-intensive services at ease.
Digital Twin Network,
Intelligent O&M functions are supported, including visualized fault locating, local network optimization, service network optimization, and VIP area network optimization.
Comparison
Protocol
Max. data rate
MIMO
CWDM
RG-MAP920-SF-M
Wi-Fi 7 (802.11be)
3.570 Gbps
2.4 GHz: 2×2
5 GHz: 2×2
1 x 2.5GE SFP port
Bluetooth 5.3
16.8 W
RG-MAP852-SF-M
Wi-Fi 6 (802.11ax)
2.976 Gbps
2.4 GHz: 2×2
5 GHz: 2×2
1 x 2.5GE SFP port
Bluetooth 5.1
1,024 (512 STAs per radio)
11 W
86 mm x 160 mm x 32.5 mm
RG-MAP852-SF-S
Wi-Fi 6 (802.11ax)
1.775 Gbps
2.4 GHz: 2×2
5 GHz: 2×2
1 x 1000BASE-X LC port
1 x 10/100/1000BASE-T port
11 W
86 mm x 160 mm x 30 mm
RG-MAP920-SF-M
Channel:
2 spatial streams
Channel:
Channel:
802.11be
Channel:
● 2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 2.3 dBi.
● 5 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3.4 dBi.
1 x 2.5GE SFP port
1 x micro USB console port
1 x Bluetooth 5.3
1 x system status LED
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Shipping: 177 mm x 127 mm x 63 mm (6.97 in. x 5.00 in. x 2.48 in.)
Main unit: 0.3 kg (0.66 lbs)
Shipping: 0.45 kg (0.99 lbs)
Kensington lock
● 48 V DC/0.35 A power input over DC connector
● If DC power is adopted, 802.3af (PoE) is used by default. When the DC output power is 16.8 W or higher, run the following commands to switch to 802.3at (PoE+).
● If the AP adopts DC power, a DC adapter with a power of less than 100 W is required.
● Idle mode: 10.6 W
512 MB, 256 MB flash
● Minimum transmit power: 12 dBm (15.85 mW)
RG-MAP920-SF-M
2.4 GHz 802.11g
–93 dBm
–83 dBm
17 dBm
–74 dBm
2.4 GHz 802.11n (HT20)
–93 dBm
–74 dBm
2.4 GHz 802.11n (HT40)
–90 dBm
–71 dBm
2.4 GHz 802.11ax (HE20)
–93 dBm
14 dBm
–64 dBm
2.4 GHz 802.11ax (HE40)
14 dBm
2.4 GHz 802.11be (EHT20)
–90 dBm
14 dBm
–64 dBm
2.4 GHz 802.11be (EHT40)
13.5 dBm
5 GHz 802.11a
–78 dBm
17 dBm
–72 dBm
5 GHz 802.11n (HT20)
–92 dBm
–73 dBm
5 GHz 802.11n (HT40)
15 dBm
–70 dBm
5 GHz 802.11ac (VHT20)
–92 dBm
–72 dBm
5 GHz 802.11ac (VHT40)
–88 dBm
14 dBm
–64 dBm
5 GHz 802.11ac (VHT80)
17 dBm
14 dBm
5 GHz 802.11ax (HE20)
–92 dBm
14 dBm
–62 dBm
5 GHz 802.11ax (HE40)
14 dBm
–59 dBm
5 GHz 802.11ax (HE80)
17 dBm
–86 dBm
14 dBm
–62 dBm
13 dBm
–56 dBm
5 GHz 802.11ax (HE160)
15 dBm
–83 dBm
12 dBm
–59 dBm
12 dBm
–52 dBm
5 GHz 802.11be (EHT80)
17 dBm
–86 dBm
14 dBm
–62 dBm
13 dBm
–56 dBm
MCS13
12 dBm
–51 dBm
5 GHz 802.11be (EHT160)
15 dBm
–83 dBm
12 dBm
–59 dBm
12 dBm
–52 dBm
MCS13
10 dBm
–50 dBm
RG-MAP920-SF-M
RGOS11.9(6)W3B19 or later
Maximum number of WLAN IDs
Mobile unit (MU) location
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES), and WPA3
Dynamic Policy
MAC address table size: 1,024
Jumbo frame length: 1,518
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Fault detection and alarming
RG-MAP920-SF-M
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-MAP920-SF-M] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijienetworks.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-MAP920-SF-M] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijienetworks.com/.
RG-MAP920-SF-M
Wi-Fi 7 dual-radio optical micro access point for Ruijie SOE Solution
● Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 688 Mbps
802.11a/b/g/n/ac/ax/be, switching between Fat, Fit, and cloud modes, and 802.3af/at-compliant (PoE/PoE+) and local power supply
● The DC power supply needs to be purchased separately, and the output voltage/current must be 48 V/0.35 A.
RG-AM5528-SF
24 x 1GE/2.5GE downlink SFP ports
24 × PoE-out ports (with four ports supporting PoE/PoE/PoE++)
4 x 10GE SFP+ ports
In i-Share mode, each master AP consumes eight wireless controller licenses.
RG-HybridBox
RG-24DUP1DB48LC
1 x DB-78 power connector
RG-OEHC-SM-1B6A2-2x0.5-I-305
RG-OEHC-SM-2B6A2-2x1.5-O-1000
加载失败
TOP
