RG-S7610-10SFG2CQ Switches - 1
RG-S7610-10SFG2CQ Switches - 2
RG-S7610-10SFG2CQ Switches - 3
RG-S7610-10SFG2CQ Switches - 4
RG-S7610-10SFG2CQ Switches - 5
RG-S7610-10SFG2CQ Switches - 6
RG-S7610-10SFG2CQ Switches - 7
RG-S7610-10SFG2CQ Switches - 8
RG-S7610-10SFG2CQ Switches - 9
RG-S7610-10SFG2CQ Switches - 10
RG-S7610-10SFG2CQ Switches - 11
RG-S7610-10SFG2CQ 1 U Ultra High-Density CWDM Fixed Core Switch
Serie
  • Ten SFG ports (equivalent to 80 SFP channels) and two 100GE uplink ports, backward compatible with 40GE, and allowing flexible configuration
  • Combination with the INC, offering simplified and efficient O&M
RG-S7610-10SFG2CQ Ultra High-Density CWDM Fixed Core Switch
Ten SFG hyper-converged ports are provided with each supporting up to eight SFP channels. This supports connections for up to 80 devices simultaneously. High-density connections can be established in this 1U switch, and two 100GE QSFP28 uplinks and one expansion slot for connecting devices such as servers and regular switches are available to support diversified configurations.
and High Performance
Hot-swappable Redundant Power
Hot-swappable Redundant Fan
Quick onboarding
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Module service port
M7600-4GT4VS:
● 4 x 10/100/1000BASE-T ports
● 4 x 25GE SFP28 ports
M7600-2CQ:
● 2 x 40GE/100GE QSFP28 ports (supporting 4 x 10GE/4 x 25GE)
4 x fan module slots (3+1 redundancy, at least three fan modules configured)
3 x fan module slots (2+1 redundancy, at least two fan modules configured)
M7600-2CQ
M7600-4GT4VS
RG-PA550I II-F
S7610-FAN I-F
S7620-FAN I-F
System specifications
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Packet forwarding rate *1
714 Mpps
1786 Mpps
833 Mpps
2976 Mpps
960 Gbps
2.4 Tbps
1.12 Tbps
4 Tbps
8 GB
4 GB DDR4
36 MB
128,000
96,000
350,000 (shared with IPv6 routing)
4000
65,000
Ingress: 28,000
Egress: 4,000
*1 means the system's packet forwarding rate.For the latest parameters, visit the Ruijie official website.
*2 means the system's switching capacity.For the latest parameters, visit the Ruijie official website.
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
RG-PA550I II-F (AC input):
RG-PA550I II-F: 550 W
270 W
450 W
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
9.73 kg (21.45 lbs)
14.4 kg (31.75 lbs)
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Front-to-back airflow
27°C (80.6°F): 56 dB
45°C (113°F): 72 dB
3+1 redundancy, and at least three fan modules required
Fan failure alarm
Power port: 6 kV
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
IEC 62368-1: 2018
EN 62368-1: 2014+A11:2017
EN 55032:2015+A1:2020
EN IEC 61000-3-2:2019+A1:2021
EN 55035:2017+A11:2020
EN 300386 V2.2.1
Ordering Information
Device Model
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
IP service
Static ARP
DHCPv6 server, DHCPv6 client, DHCPv6 relay, and DHCPv6 snooping
GRE tunnel
Graceful restart (GR)
IPv4 IS-IS
IPv6 IS-IS
IPv4/IPv6 VRF
IPv4/IPv6 PBR
PIM-SM
PIM-DM
MLDv1 and MLDv2
MLD snooping
MPLS MIB (RFC 1273, RFC 4265, and RFC 4382) (MPLS MIB, MPLS L3VPN STD MIB, MPLS LSR STD MIB, and MPLS VPN MIB)
Expert-level ACLs (hardware ACLs based on the source and destination IP addresses and ports, and protocol type)
ACL 80
Port-based rate limiting
RADIUS authentication and authorization
IEEE 802.1X authentication, MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication
Loose and strict RPF
uRPF ignoring default routes
Device Virtualization
RSPAN and ERSPAN
FTP and S TFTP
VLAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv4
VXLAN EVPN
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
Información del pedido
Perform the following steps to configure an RG-S7600:
  • Select the chassis based on the specific product model.
  • Select power modules based on power supply requirements. At least one power module is required.
  • Select expansion modules as required.
    RG-S7610-10SFG2CQ
    RG-S7610-10SFX2CQ
    RG-S7620-20SFG2CQ
    RG-S7620-20SFX2CQ
    M7600-2CQ
    Expansion module, 2 x 40GE/100GE QSFP28 ports. One 40GE port can be split into four 10GE ports and one 100GE port can be split into four 25GE ports.
    M7600-4GT4VS
    Expansion module, 4 x 10/100/1000BASE-T ports, 4 x 1GE/10GE/25GE SFP28 ports.
    RG-PA550I II-F
    550 W AC power module, supporting redundancy, 10 A power cord
    1GE Optical Transceiver
    40GE Optical Transceiver
    100GE Optical Transceiver
    Core switch side, 1G BASE-LR,SFG Transceiver, 8 different wavelengths (10km, LC)
    Core switch side, 10G BASE-LR, SFP+ Transceiver, 8 different wavelengths (10km, LC)
