RG-N18010-XH Switches - 1
RG-N18010-XH Switches - 2
RG-N18010-XH Switches - 3
RG-N18010-XH Switches - 4
RG-N18010-XH Switches - 5
RG-N18010-XH Switches - 6
RG-N18010-XH Switches - 7
RG-N18010-XH Switches - 8
RG-N18010-XH Switches - 9
RG-N18010-XH Switches - 10
Serie
Key Specification View More
Data Center 400GE Modular
Core Switch
RG-N18010-XH
expansion needs.
networks.
Zero Midplane
Clos Architecture
Hardware-level Redundancy,
Center Network Stability
SFUs in N+1 Redundancy Mode
efficient heat dissipation.
Supervisor Engin es in 1+1 Redundancy Mode
the switch.
RG-N18010-XH
Switching Capacity
645 Tbps/1,935 Tbps
Packet Forwarding Rate
345,600 Mpps
Slots
Module Slots
10 (2 for supervisor modules)
Switch Fabric Module Slots
Three fan module slots
Ten power module slots
Without cable management brackets: 442 mm x 896 mm x 708 mm (17.40 in. x 35.28 in. x 27.87 in., 16 RU)
With cable management brackets: 442 mm x 935 mm x 708 mm (17.40 in. x 36.81 in. x 27.87 in., 16 RU)
96.4 kg (212.53 lbs., including the fan)
RG-PAH3000I-F:
● AC: 100 V AC to 176 V AC, power: 1,500 W
● AC: 176 V AC to 240 V AC, power: 3,000 W
● HVDC: 240 V DC to 380 V DC, power consumption: 3,000 W
Airflow direction
Front-to-rear
Maximum Power Consumption
18,760 W
312,683 hours
Operating Temperature
0ºC to 40ºC (32ºF to 104ºF)
Storage Temperature
–40ºC to +70ºC (–40ºF to +158ºF)
Operating Humidity
5% to 95% RH (non-condensing)
● Operating altitude for long-term working conditions: up to 5000 m (16404.20 ft.). At 1800 m (5905.51 ft.), the maximum operating temperature is 40°C (104°F). The maximum operating temperature decreases by 1°C (1.8°F) per 200 m (656.16 ft.) increase in altitude.
● Operating altitude: up to 5,000 m (16404.20 ft.)
● Storage altitude: up to 5,000 m (16404.20 ft.)
RG-N18010-XH
Traffic Analysis
IPFIX
Layer 2 Features
Jumbo frame
IEEE 802.3ad (static link aggregation, LACP, cross-card link aggregation, cross-device link aggregation)
IEEE 802.1Q
STP, RSTP, MSTP
QinQ
IPv4 Features
Policy-based routing
Manual tunnel and GRE tunnel
IPv6 Features
VRRPv3
Path MTU Discovery
Pingv6, telnetv6, FTPv6, TFTPv6, DNSv6, ICMPv6
IGMP v1/v2/v3
IGMP snooping
IGMP proxy
MLDv1, MLDv2
Multicast static routing
Fast leave
MPLS LDP
#SR MPLS (Segment Routing)
#SR-TE
Ingress and egress ACLs
IPv6 ACLs
Priority marking/remarking
Multiple queue scheduling mechanisms, including SP(PQ), DRR, SP(PQ) + DRR, WFQ, SP(PQ) + WFR,
Ingress and egress rate limiting, CAR
#MPLS QoS
Data center features
#SRv6
VXLAN bridge
VXLAN gateway
BGP-EVPN VXLAN
VXLAN mapping
IPv6 VXLAN over IPv4
MLAG
SDN
OpenFlow 1.3.
N+M redundancy for power modules and fans
Backplane-free design to avoid single point of failures
Hot swapping of components
Hot patch function and online installation of patches
BPDU Guard/Loop Guard/Root Guard
NSR
FRR
GR for OSPF/IS-IS/BGP
Virtual Switching Unit 3.0
MACSec
Network Foundation Protection Policy (NFPP) and CPU protection policy (CPP) to prevent protocol packet attacks
uRPF
Source IP address restriction
FTP, TFTP, Xmodem, and SFTP SNMP V1/V2c/V3
RMON
NTP clock
Fault alarm and auto-recovery
Traffic analysis
Zero-touch provisioning (ZTP)
Telemetry
* indicates that the feature will be available in the future.
# indicates that the feature is supported by only CE cards.
RG-N18010-XH
Safety
● IEC 62368-1
● EN IEC 62368-1
● GB 4943.1
● EN 55032
● EN 55035
● EN IEC 61000-3-2
● EN 61000-3-3
● EN 300 386 V2.2.1
● GB/T 9254.1
● 2011/65/EU EN 50581
● 2012/19/EU EN 50419
● (EC) No.1907/2006
● GB/T 26572
Información del pedido
RG-N18010-XH
RG-N18010-XH chassis, excluding power modules, with all fans
M18000XH-CM
M18000XH-CM supervisor module
Power Modules
RG-PAH3000I-F
3000 W AC power module (AC and 240 V to 380 V HVDC)
Switch Fabric Modules
M18018XH-FE-E IV
Type-E switch fabric module II for RG-N18010-XH, used together with CE cards
M18010XH-FE-E II
Line Cards
M18000XH-36QC-CES
Line card with 36 x 400GE QSFP-DD ports, used together with Type-E switch fabric modules
M18000XH-48CQ-CES
Line card with 48 x 100GE QSFP28 ports, used together with Type-E switch fabric modules
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
400G-QDD-ZR-SM1550
400G ZR transceiver, QSFP-DD form factor, Duplex LC, 1550 nm, 80 km (262,467.19 ft.) over SMF
400G-QDD-ZR+-SM1550
400G ZR+ transceiver, QSFP-DD form factor, Duplex LC, tunable wavelength, P2P distance of up to 120 km (393,700.79 ft.) over SMF
400G-QDD-SR8-MM850
400G SR8 module, QSFP-DD form factor, MPO-16 APC, 850 nm, 100 m (328.08 ft.) over MMF
100G AOC cable, QSFP28 form factor, 5 m (16.40 ft.)
100G AOC cable, QSFP28 form factor, 10 m (32.81 ft.)
40GBASE Series Optical Transceivers
40G SR transceiver, QSFP+ form factor, MPO, 150 m (492.13 ft.) over MMF
40G AOC cable, QSFP+ form factor, 30 m (98.43 ft.)
25GBASE Series Optical Transceivers
VG-SFP-AOC5M
25G AOC cable, SFP28 form factor, 5 m (16.40 ft.)
VG-SFP-SR-SM850
25G SR transceiver, SFP28 form factor, LC, 850 nm, 100 m (328.08 ft.) over MMF
25G LR4 transceiver, QSFP28 form factor, LC, 1310 nm, 10 km (32,808.40 ft.) over SMF
