RG-S2915-10GT2MS-P-L Commutateurs - 1
RG-S2915-10GT2MS-P-L Commutateurs - 2
RG-S2915-10GT2MS-P-L Commutateurs - 3
RG-S2915-10GT2MS-P-L Commutateurs - 4
RG-S2915-10GT2MS-P-L Commutateurs - 5
RG-S2915-10GT2MS-P-L Commutateurs - 6
RG-S2915-10GT2MS-P-L Commutateurs - 7
RG-S2915-10GT2MS-P-L Commutateurs - 8
RG-S2915-10GT2MS-P-L Commutateurs - 9
RG-S2915-10GT2MS-P-L Commutateurs - 10
RG-S2915-10GT2MS-P-L Commutateurs - 11
RG-S2915-10GT2MS-P-L 10-Port 1GE RJ45 Layer 2+ Managed PoE+ Switch, 2-Port 2.5GE Uplink
Key Specification View More
Fixed Service Ports
10 × 10/100/1000BASE-T ports, ports 1 to 8 supporting PoE/PoE+
2 × 1GE/2.5GE SFP ports
Management port
30 Gbps
22.5 Mpps
Capacity of MAC address table
16000
1 x fixed power module
1 x fan module
Cooling mode
Fan cooling
Input power
Rated input voltage range: 100V AC to 240V AC, 50/60Hz
Max. input voltage range:90V AC to 264V AC, 50/60Hz
141W (PoE budget: 125W)
10 kV
297 mm × 170 mm × 44.5 mm (11.69 in. x 6.69 in. × 1.75 in.)
3 years
Killer Layer 2+ Access Switch
Applications
and Wider Coverage
10 kV Surge Protection
and Uninterrupted Connection
Port Specifications
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
RG-S2915-24GT4MS-P-L
Fixed Service Ports
4 x 1GE/2.5GE SFP ports
24 x
2 x 1GE/2.5GE SFP ports
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
87 Mpps
51 Mpps
51 Mpps
22.5 Mpps
116 Gbps
68 Gbps
68 Gbps
30 Gbps
64 MB
512 MB DDR4
512 KB
MAC Table Capacity
ARP table
512
ACL entries
500
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
(W x D x H) 1*
570 mm x 490 mm x 390 mm
580 mm x 450 mm x 380 mm
2.8 kg (6.17 lbs)
2.5 kg (5.51 lbs)
2.8 kg (6.17 lbs)
2.5 kg (5.51 lbs)
Shipping weight 1*
20.43 kg
(45.04 lbs)
18.18 kg
(40.08 lbs)
20.93 kg
(46.14 lbs)
15.98 kg
(35.23 lbs)
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
AC input:
AC input:
AC input:
AC input:
30 W
15.6 W
33 W (non-PoE)
403 W (full PoE load)
16 W (non-PoE)
141 W (full PoE load)
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
Forced air cooling
Forced air cooling
Forced air cooling
≤ 37 dB
≤ 39 dB
≤ 37 dB
Air discharge: 8 kV/15 kV
Contact discharge: 6 kV/8 kV
Power port: 6 kV/2 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
IEEE 802.1Q (4,094 VLANs)
Port based VLAN
RIP, RIPng
OSPFv2
ACL 80
SSHv1, SSHv2
IGMP V1,V2 snooping
IP Source Guard
Temperature Monitoring
Temperature Alarm
Overtemperature Protection
RSPAN
NTP
TFTP client
Informasi Pemesanan
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
Optical Transceivers
Are there any recommended RG-S2915-L series switches provide PoE power supply?
The RG-S2915-10GT2MS-P-L and RG-S2915-24GT4MS-P-L are recommended. They provide up to 30 W power per port to meet power supply needs of terminals such as VoIP phones, IP cameras, and access points (APs).
236
Because our equipment room is near meetings rooms, we are concerned about noises caused by switches. Can we use the RG-S2915-24GT4MS-L switch in such a scenario?
Yes. The RG-S2915-24GT4MS-L switch adopts a fanless design and dissipates heat in a natural manner without noise. Even if your office is near the equipment room, you are free of worries about noises. The switch also supports energy efficient Ethernet (EEE). Idle ports shut down automatically to save power.
230
Are 2.5G fiber ports of the switch backward-compatible?
Yes. The 2.5G fiber ports of the switch are compatible with SFP transceiver modules and backward-compatible with 1000 Mbps.
235
加载失败
TOP
