RG-S6910-3C Switch - 1
RG-S6910-3C Switch - 2
RG-S6910-3C Switch - 3
RG-S6910-3C Switch - 4
RG-S6910-3C Switch - 5
RG-S6910-3C Switch - 6
RG-S6910-3C Switch - 7
RG-S6910-3C Switch - 8
RG-S6910-3C – Data Center 100GE High-Density Modular Core Switch (Backward Compatible with 40GE) in the 4-RU Space
16 GB buffer that supports high-performance routing connections, and future evolution to 400GE data center network
  • Various ports, 100GE line cards, and up to 96 x 100GE ports
  • Support of IPv4/IPv6 dual-stack protocols, providing flexible networking
Spesifikasi Penting View More
Switching Capacity
19.2 Tbps
Packet Forwarding Rate
4000 Mpps
Expansion Modules
Four power module slots
Six fan module slots
Dimensions (W × D × H)
442 mm x 735 mm × 173.6 mm (17.40 in. x 28.94 in. x 6.83 in.,4 RU)
Maximum Power Consumption
Max: 2046 W
Typical: 1092 W
Static: 760 W
100GE/400GbE ports
Operating Temperature
0ºC to 40ºC (32ºF to 104ºF)
Operating Humidity
10% RH to 90% RH (Non-condensing)
Data Center 100GE DCI Core Switch RG-S6910-3C
16 GB powerful buffer capability and buffer scheduling mechanism, providing a maximum of 96 x 100GE ports within 4 RU height,
which is suitable for DCI core scenarios in data centers
Support of high-performance routing connections, meeting future expansion needs of data center networks
Power modules in 2+2 redundancy mode, hot swapping, and failover in seconds, providing nonstop services
RG-S6910-3C
100GE/400GbE ports
Slots
Expansion Module Slots
Three expansion slots, each slot supporting the line card with 32 x 100GbE ports or 8 x 400GbE ports
Management Port
One management port, one console port, and one USB port
Switching Capacity
19.2 Tbps
4000 Mpps
802.1Q VLAN
4094
(W × D × H)
About 42 kg (92.59 lbs., including four power modules, six fans, and three subcard modules)
AC
● Rated voltage: 110 V AC/ 220 V AC
● Rated voltage range: 100 V AC to 240 V AC, 50 Hz to 60 Hz
● Max voltage range: 90 V AC to 264 V AC, 47 Hz to 63 Hz
High-voltage DC
Input voltage range: 180 V DC to 300 V DC
● Max: 2046 W
● Typical: 1092 W
● Static: 760 W
-40 °C to +70 °C (-40 °F to +158 °F)
Operating Humidity
5% to 95% RH (non-condensing)
Working altitude
Operating altitude: up to 5000 m (16,404.20 ft.)
Storage altitude: up to 5000 m (16,404.20 ft.)
RG-S6910-3C
Docker
gRPC APIs in Docker
L2 Protocols
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (link aggregation), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), IGMP Snooping, Jumbo Frame (9 KB), IEEE 802.1ad (QinQ), GVRP
L3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing, Route-policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, Any-RP
IPv6 Basic Protocols
IPv6 Features
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, manual tunneling, IPv4 over IPv6 tunneling
Visualization
sFLOW and IPFIX
IGMP Proxy、IGMP v1, v2, v3、IGMP Host Behavior、Querier Election、Member Query and Response、Static Multicast Route、IGMP Fast Leave、IGMP Filter、Layer-2 Multicast Forwarding Without Packet Loss、IGMPv1 and IGMPv2 Snooping、IVGL Mode、Querier、Source IP Address Check、Source Port Check、MLD Proxy、MLD v1 and v2、MLD Snooping、Coping with Traffic Burst Without Packet Loss、Layer-2 Multicast Forwarding Without Packet Loss、Source Port Check、MSDP、PIM-DM、PIM-SMv6、PIM-SSMv6、PIM-SM、PIM-SSM
ACL 80、Dual-stack Networking、ACL-based Redirection、IPv6 ACL、Standard IP-based ACL、Extended IP-based ACL、Extended MAC-based ACL、Ingress/Egress ACLs、Time-based ACL、Global ACL、ACL Counter、ACL Logging、ACL Re-marking、Displaying ACL Resource Usage、Expert-level ACL
Mapping of 802.1p, DSCP, and ToS priorities, ACL-based traffic classification, priority marking/remarking, multiple queue scheduling mechanisms available including SP, WFQ, and SP+WRR
Data center features
The MMU queue ID ranges from 0 to 7.
Buffer Occupation/Queue Traffic Statistics/Packet Loss Report Through gRPC
Flow Suspension Prevention
MMU
Displaying Lost Packets and Alarms Due to Buffer Congestion on an Interface
Real-Time Buffer Monitoring
Reading Statistics of Unicast Packet Loss Due to Buffer Congestion Through MIB
HA Design
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy and fan redundancy, and hot swap for all cards and power modules
Security Features
Network foundation protection policy, CPP, DDoS attack defense, illegitimate packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, and SPAN/RSPAN/ERSPAN
Other Protocols
Specification
RG-S6910-3C
Safety
● UL 62368-1
● CSA C22.2 No. 62368-1
● IEC 62368-1
● EN 62368-1
● BS EN 62368-1
● GB 4943.1
● EN 55032
● EN 55035
● EN 61000-3-2
● EN 61000-3-3
● BS EN55032
● BS EN 55035
● BS EN 61000-3-2
● BS EN61000-3-3
● EN 300 386
● ANSI C63.4
● 47 CFR FCC Part 15 Subpart B
● ICES-003 Issue 7
● GB/T 9254.1
● 2011/65/EU EN 50581
● 2012/19/EU EN 50419
● (EC) No.1907/2006
● GB/T 26572
Chassis, Expansion Cards, Fan Modules, and Power Modules
RG-S6910-3C
Three expansion slot, four power module slots, and six fan module slots
M6900-32CQ
32-port 100GbE card
RG-PA1200I-F
RG-S6910-3C power module, supporting 2+2 redundancy, hot swapping, and front-to-rear ventilation design
M2EFAN I-F
RG-S6910-3C fan module, supporting 5+1 redundancy, hot swapping, and front-to-rear ventilation design
40GBASE Series Optical Modules
40G QSFP+ AOC cable, 30 m (98.43 ft.)
40G QSFP+ AOC cable, 5 m (16.40 ft.)
加载失败
TOP
