RG-SF2920-16GT2SFP-P Switches - 1
RG-SF2920-16GT2SFP-P Switches - 2
RG-SF2920-16GT2SFP-P Switches - 3
RG-SF2920-16GT2SFP-P Switches - 4
RG-SF2920-16GT2SFP-P Switches - 5
RG-SF2920-16GT2SFP-P Switches - 6
RG-SF2920-16GT2SFP-P 16-Port GE All-Optical PoE Switch, 2 × Gigabit Uplink Optical Ports
  • Various port combinations, surge protection greater than 8 kV, 16 x 10/100/1000BASE-T ports, ports 1 to 8 PoE/PoE+ supported, and 2 x 1GE SFP ports for uplink
Key Specification View More
2 x 1GE SFP ports
System packet forwarding rate
26.8 Mpps
System switching capacity
25 W (without PoE load)
150 W (full PoE load)
Warranty period
3 years
All-Optical Ethernet Switch RG-SF2920-16GT2SFP-P
This switch provides 16 x 10/100/1000BASE-T ports, ports 1 to 8 PoE/PoE+ supported, 2 x 1GE SFP uplink ports, rich interfaces, supporting full service expansion.
and No Security Concern
Flexible Installation
Heat Dissipation Design
Quietness
Optical Link O&M
Port Specifications
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
8 x 10/100/1000BASE-T ports
1 x 1GE/2.5GE SFP port
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2MG2XS
RG-SF2920-16GT2SFP
2 x 1G/2.5GBASE-T ports
2 x 1GE/10GE SFP+ ports
2 x 1GE SFP ports
RG-SF2920-8GT2MG2XS-P
RG-SF2920-16GT2MG2XS-P
2 x 1GE SFP ports
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
16 Mpps
9.7 Mpps
16 Mpps
System switching capacity *2
21 Gbps
13 Gbps
21 Gbps
1 MB
Ingress: 1,500
Egress: 500
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
49.1 Mpps
61 Mpps
26.8 Mpps
66 Gbps
82 Gbps
256 MB
512 MB DDR3
1.5 MB
500
500
Ingress: 1,500
Egress: 500
26.8 Mpps
56.5 Mpps
68.44 Mpps
76 Gbps
92 Gbps
256 MB
512 MB DDR3
1.5 MB
500
500
Ingress: 1,500
Egress: 500
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
1.18 kg (2.6 lbs)
1.43 kg (3.15 lbs)
1.74 kg (3.84 lbs)
1.98 kg (4.37 lbs)
2.23 kg (4.92 lbs)
2.54 kg (5.60 lbs)
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
1.97 kg (4.34 lbs)
2.04 kg (4.5 lbs)
1.98 kg (4.37 lbs)
2.75 kg (6.06 lbs)
2.81 kg (6.19 lbs)
2.75 kg (6.06 lbs)
2.34 kg (5.16 lbs)
2.33 kg (5.14 lbs)
2.33 kg (5.14 lbs)
3.11 kg (6.86 lbs)
3.12 kg (6.88 lbs)
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
1 x fixed power module
Fixed power supply: 25 W
Fixed power supply: 70 W
Fixed power supply: 150 W
The maximum power is 45 W
8.5 W
10 W (without PoE load)
55 W (full PoE load)
16.5 W (without PoE load)
141.5 W (full PoE load)
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
RG-SF2920 Series
Operating temperature:
Note: At an altitude between 1,800 m (9,842.52 ft.) and 5,000 m (16,404.20 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F).
Air discharge: 15 kV
Contact discharge: 8 kV
Service port: 8 kV
RG-SF2920 Series
RG-SF2920U
RSTP (IEEE 802.1w)
SNTP
MQTT
Syslog/Debugging
RG-SF2920
MAC VLAN
Basic QinQ and flexible QinQ
Static blackhole routing
ACL80 and IPv6 ACLs
SSHv1.5 and SSHv2.0
Portal authentication
Unknown unicast suppression
Load balancing
LACP dynamic aggregation
Cross-VSU aggregate interface
IPv4 VRRP v2/v3, IPv6 VRRPv3
GR for OSPF
SPAN, RSPAN and ERSPAN
Flow- and VLAN-based SPAN
● Port priority
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
1000BASE-LH, SFP transceiver, TX1550/RX310, BiDi LC, 40 km over SMF
CWDM
XG-SFP-LR(A1-4)-H
Access switch side, 10G BASE-LR, SFP+ Transceiver, 4 different wavelengths (10km, LC),used in dual uplink scenarios
Access switch side, 10G BASE-LR, SFP+ Transceiver, 8 different wavelengths (10km, LC),used in dual uplink scenarios
GE-SFP-LR(A1-4)-H
Access switch side, 1G BASE-LR, SFG Transceiver, 4 different wavelengths (10km, LC),used in dual uplink scenarios
Access switch side, 1G BASE-LR, SFG Transceiver, 8 different wavelengths (10km, LC),used in dual uplink scenarios
How to ensure safety when installing an SF series all-optical switch in a telecommunication box?
The switch size is smaller than that of the previous generation. The regulation-compliant open area, excellent space layout, and right-angle power plug ensures security. The innovative shark fin design increases the heat dissipation area and improves heat dissipation efficiency, making the operation safer.
23
How to simplify O&M for the SF series all-optical switches?
The switch can be used in combination with the INC controller, to implement fast onboarding, plug and play, and no commissioning. The link fault locating function, together with the INC controller, allows you to check the link health status and alarms, improving the troubleshooting efficiency and achieving zero touch replacement. Traffic routes do not need to change, and different switches can be flexibly used for replacement as required.
20
加载失败
TOP
