RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 1
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 2
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 3
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 4
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 5
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 6
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 7
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 8
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 9
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 10
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 11
RG-CS86-24XMG4XS4VS-UPD Коммутаторы - 12
RG-CS86-24XMG4XS4VS-UPD 24-Port Multi-GE Switch with Cloud Management, Full 1GE/2.5GE/5GE/10GE Access with PoE++
  • 24 x 100/1000/2.5G/5G/10GBASE-T ports for access, 4 x 1GE/10GE SFP+ ports and 4 x 10GE/25GE SFP28 ports for uplink, meeting high-bandwidth campus network demands
Функции
RG-CS86-24XMG4XS4VS-UPD, 10GE Multi-rate Access Switch
4 x 10GE SFP+ ports and 4 x 25GE SFP28 ports for uplink, enabling flexible networking High-power PoE++, offering up to 90 W output and adapting to services in Wi-Fi 6E and Wi-Fi 7 eras
Optical Port Fault Isolation
Flexible management modes
Технические характеристики
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
RG-CS86-48MG4VS2QXS-UPD
● Ports 1 to 24 support PoE++
2 x 40GE QSFP+ ports
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
327 Mpps
327 Mpps
565 Mpps
625 Mpps
440 Gbps
440 Gbps
760 Gbps
840 Gbps
Switch buffer
32,768
Ingress: 2,500
Egress:1,000
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
568 mm x 366 mm x 226 mm
563 mm x 563 mm x 210mm
3.65 kg (8.82 lbs)
6.11 kg (13.47 lbs)
5.37 kg (11.84 lbs)
8.12 kg (17.90 lbs)
8.42 kg (18.56 lbs)
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
Built-in power supply: 460 W
90 W (without PoE)
460 W (full PoE load)
1+1 power redundancy
150 W (without PoE)
1,800 W (full PoE load)
200 W (without PoE)
● 1 x RG-PA600I-P-F:450 W
● 2 x RG-PA600I-P-F:930 W
● 1 x RG-PA600I-P-F:400 W
● 2 x RG-PA600I-P-F:880 W
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
3 x pluggable fan modules
2+1 redundancy
27°C (80.6°F): 40 dB
45°C (113°F): 78 dB
45°C (113°F): 78 dB
27°C (80.6°F): 60 dB
45°C (113°F): 78 dB
45°C (113°F): 78 dB
Temperature alarming
Service port: 4 kV
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
Super VLAN, Private VLAN
Flexible QinQ
IP Routing
GR for RIP, OSPF, BGP
Информация для заказа
RG-CS86-24MG4VS-UP
fixed AC power supply and fan
RG-CS86-12XMG4VS-UP
25GE
VG-SFP-AOC7M
