RG-S6510-4C Коммутаторы - 1
RG-S6510-4C Коммутаторы - 2
RG-S6510-4C Коммутаторы - 3
RG-S6510-4C Коммутаторы - 4
RG-S6510-4C Коммутаторы - 5
RG-S6510-4C Коммутаторы - 6
RG-S6510-4C Коммутаторы - 7
RG-S6510-4C 100GE Data Center Access Switch
  • 96 x 25GE ports and 8 x 100GE ports, 32 x 100GE ports, or 64 x 40GE ports housed in a 2 RU enclosure for flexible networking
Key Specification View More
Функции
Data Center 100GE Access Switch RG-S6510-4C
100GE high-density modular access switch with 10G/25G/40G/100GE downlink ports
96 x 25GE ports and 8 x 100GE ports, 32 x 100GE ports, or 64 x 40GE ports housed in a 2 RU enclosure for adaptation to different scenarios
De-stacking
M-LAG
Технические характеристики
RG-S6510-4C
25GE, 40GE, and 100GE ports
Slots
Expansion Modules
M6500-24VS2CQ, M6500-08CQ
Expansion Module Slots
Power supply module slots
Fan module slots
Management Port
One management port, one console port, and one USB port, compliant with the USB2.0 standard
Switching Capacity
6.4 Tbps
Packet Forwarding Rate
2030 Mpps
802.1Q VLAN
4094
(W × D × H)
442 mm x 520 mm x 86 mm (17.40 in. x 20.47 in. x 3.39 in., 2 RU)
About 14 kg (30.86 lbs., including power supply modules and fan modules)
AC
Rated voltage: 110 V/220 V
Rated voltage range: 100 V AC to 240 V AC, 50 Hz to 60 Hz
Maximum voltage range: 90 V AC to 264 V AC, 47 Hz to 63 Hz
Rated input current: 5 A to 10 A
High-voltage DC
RG-PA800I-F module
● HVDC voltage range: 180 V DC to 310 V DC
● Rated voltage: 240 V DC
● Max input current: 5 A
RG-PD800I-F module
● Rated voltage range: –36 V DC to –72 V DC
● Rated voltage: –48V DC
● Max input current: 23 A
Maximum Power Consumption
● Max: 650 W
● Typical: 455 W
● Static: 202 W
Operating Temperature
0ºC to 40ºC (32ºF to 104ºF)
-40 °C to 70 °C (-40 °F to 158 °F)
Operating Humidity
10% RH to 90% RH (Non-condensing)
5% to 95% RH (non-condensing)
Working altitude
Operating altitude: up to 5000 m (16,404.20 ft.)
Storage altitude: up to 5000 m (16,404.20 ft.)
RG-S6510-4C
Virtual Switching Unit 3.0
L2 Protocols
L3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing (PBR), Route-policy, Equal-Cost Multi-Path Routing (ECMP), WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, Any-RP
IPv6 Basic Protocols
IPv6 Features
Data Center Features
EVPN VXLAN
IPv6 VXLAN over IPv4
RDMA
M-LAG
OpenFlow 1.3
Visualization
sFLOW sampling
INT
Standard IP-based ACL、Extended MAC-based ACL、Extended IP-bsaed ACL、Expert-level ACL、ACL 80、IPv6 ACL、ACL Logging、Ingress/Egress ACLs、ACL Counter (Ingress and egress counters are supported in interface or global configuration modes)、ACL Re-marking、Global ACL、ACL-based Redirection、Displaying ACL Resources、Processing First Packet of TCP Handshake When Binding the ACL to Restrict SIP、Matching Against 5-Tuple of Pass-by VXLAN Inner IP Packets、The expert-level ACL supports matching the IP flag and DSCP fields of VXLAN inner packets
Priority marking/remarking
Virtualization
Buffer Management
Buffer status monitoring and management, and identification of burst traffic
HA Design
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy, and fan redundancy, and hot swapping for all cards and power supply modules
Security Features
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, gateway ARP spoofing prevention, and ARP check
Management Mode
SNMP v1/v2c/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN, Telemetry, ZTP, Python, fan and power supply alarm, and temperature alarm
Other Protocols
Specification
RG-S6510-4C
Safety
● NM EN 62368-1
● NM CEI62368-1
● IEC 62368-1
● EN 62368-1
● BS EN 62368-1
● UL 62368-1
● CSA C22.2#62368-1
● GB 4943.1
● EN 61000-4-2
● EN 61000-4-3
● EN 61000-4-4
● EN 61000-4-5
● EN 61000-4-6
● EN 61000-4-11
● EN 55032
● EN 55035
● EN 61000-3-2
● EN 61000-3-3
● EN IEC 61000-3-2
● EN IEC 61000-3-3
● EN 300 386
● ETSI EN 300 386
● NM EN 55035
● NM EN 61000-3-2
● NM EN 61000-3-3
● BS EN 55032
● BS EN 55035
● BS EN 61000-3-2
● BS EN 61000-3-3
● CNS 13438
● FCC CFR Title 47, Part 15, Subpart B
● ANSI C63.4-2014
● ICES-003 Issue 7
● GB/T 9254.1
● 2011/65/EU EN 50581
● 2012/19/EU EN 50419
● (EC) No.1907/2006
● GB/T 26572
Информация для заказа
The configuration procedure for RG-S6510-4C series switches is as follows:
  • Select the switch, fan, and power supply modules.
  • Select expansionmodules based on port
  • Select optical transceivers.
    Chassis, Fan, and Power Supply Modules
    RG-S6510-4C
    Four expansion module slots, supporting hot swapping.
    The power supply model is RG-PA800I-F, and the fan model is M6500-FAN-F.
    RG-PA800I-F
    M6500-FAN-F
    Expansion Modules
    M6500-08CQ
    Eight QSFP28 ports
    The QSFP28 port supports a speed of 40 Gbps/100 Gbps.
    M6500-24VS2CQ
    24 25GE SFP28 ports and two QSFP28 ports
    SFP28 supports a speed of 10G/25G rates.
    The QSFP28 port supports a speed of 40 Gbps/100 Gbps. One QSFP port can be split into four 10GE or 25GE ports.
    40GBASE Series Optical Modules
    40G QSFP+ AOC cable, 30 m (98.43 ft.)
    40G QSFP+ AOC cable, 5 m (16.40 ft.)
    25GBASE Series Optical Modules
    25G LR module, SFP28 form factor, Duplex LC, 1310 nm, 10 km (32,808.40 ft.) over SMF
    VG-SFP-AOC5M
    25G SFP28 AOC cable, 5 m (16.40 ft.)
    10GBASE Series Optical Modules
    XG-LR-SM1310
    10G LR module, SFP+ form factor, Duplex LC, 10 km ((32,808.40 ft.) over SMF
    10G ER module, SFP+ form factor, Duplex LC, 40 km (131,233.60 ft.) over SMF
    10G SR module, SFP+ form factor, Duplex LC, 300 m (984.25 ft.) over MMF
    10G ZR module, SFP+ form factor, Duplex LC, 80 km (262,467.19 ft.) over SMF
    XG-SR-MM850
    1000BASE Series Optical Modules
    1G LH module, SFP form factor, Duplex LC, 40 km (131,233.60 ft.) over SMF
    1G LX module, SFP form factor, Duplex LC, 10 km (32,808.40 ft.) over SMF
    1G SR module, SFP form factor, Duplex LC, 550 m (1,804.46 ft.) over MMF
    1G ZX module, SFP form factor, Duplex LC, 80 km (262,467.19 ft.) over SMF
    1000BASE Series Electrical Modules
    Mini-GBIC-GT(F)
