RG-RSR30-XA-24 เราเตอร์ - 1
RG-RSR30-XA-24 เราเตอร์ - 2
RG-RSR30-XA-24 เราเตอร์ - 3
RG-RSR30-XA-24 เราเตอร์ - 4
RG-RSR30-XA-24 เราเตอร์ - 5
RG-RSR30-XA-24 เราเตอร์ - 6
RG-RSR30-XA-24 เราเตอร์ - 7
RG-RSR30-XA-24 เราเตอร์ - 8
RG-RSR30-XA-24 เราเตอร์ - 9
RG-RSR30-XA-24 24-Port Multi-service Fixed Aggregation Router
Recommended as an egress router for networks of public sector commission offices, government at the district and county levels.
  • Self-developed next-generation RGOS12.X and innovative architecture, providing high performance and scalability and enabling non-blocking concurrent services
24-Port High-Density 10GE Fixed Aggregation Router
RG-RSR30-XA-24
The router provides multiple WAN ports and integrates routing, security, wireless and other functions. The router is recommended as an egress router for networks of public sector commission offices, government at the district and county levels, and small and medium-sized parks, and as an aggregation router for networks of small and medium-sized enterprises.
The next-generation HSIC expansion module is supported and rich expansion modules are provided to meet various combination requirements.
Applications
4G/5G supported
Next-Generation Operating System RGOS and Innovative Architecture,Providing High-Performance and Scalability and Enabling Non-Blocking Concurrent Services
The innovative architecture combines the CPU, network chip, and service-specific chip to accelerate hardware performance, while enabling unified business scheduling. The independent operation of each business component ensures that a single business malfunction will not affect the normal operation of the entire machine.
Software-Level Dual-Boot
RG-RSR30-XA-24
16 x 10/100/1000BASE-T ports
8 x 10GE SFP+ ports
4 x expansion module slots
272 Gbps
4 Mpps
300,000
2,048
300,000
Number of IGMP groups
Number of MLD groups
150 W
● Maximum input current: 3 A
RG-PD150IB-F (DC input):
● Maximum input current: 5 A
Power output
● Output voltage: 12 V
RG-PD150IB-F: 150 W
6 kV
RG-RSR30-XA Series
Jumbo frame length: 2,000 bytes
FTP, TFTP, FTPv6, and TFTPv6
NTP, SNTP, and NTPv6
NAT
ND
DHCP server, DHCPv6 client, and DHCPv6 relay
ND and ND snooping
IPv6 GRE tunnel
IPv4 and IPv6 static routing, and static blackhole routes
BGP and BGP4+
Routing policies
BGP4, BGP4+, and MP-BGP
IGMP v1/v2/v3
Static multicast routing
Basic MPLS functions
MPLS forwarding
L3VPN
LSP
LDP
Standard IP ACLs
IPv6 ACLs
Applying ACLs to interfaces
MPLS QoS
Attack defense
Password security
RNFP
FPM
PKI
IPsec VPN(AES-128,AES-256)
VPDN
Global IP-MAC binding
Hot swapping
SPAN and ERSPAN
IPFIX
Interface
Ethernet interface
RG-RSR30-XA-24
RG-RSR30-XA-24 chassis, 8 x 10GE SFP+ WAN ports and 16 x 10/100/1000BASE-T WAN ports, 4 x Expansion module slots, 1 x USB 2.0 port (Type-A connector), 1 x RJ45 console port
Power Modules
RG-PD150IB-F
150 W DC power module
How many concurrent terminals are allowed?
The number of concurrent terminals of a router is a common performance indicator used when configuring the router as an egress router. RG-RSR30-XA-24 can support a maximum of 1,000 concurrent terminals after being configured with egress applications. For more information, visit the official website and consult pre-sales service on the right side of the web page.
191
What is the function of the FUNC button on the device?
The FUNC button on the device can be used to import configuration files through a USB drive, allowing for simple configuration and software upgrade without complicated CLI operations, thus improving deployment efficiency.
657
Is IPv6 supported by this router?
Yes. This router supports IPv4/IPv6 dual stack and multiple IPv6 routing technologies such as static routing, equal-cost multi-path routing, policy-based routing, Open Shortest Path First version 3 (OSPFv3), Routing Information Protocol Next Generation (RIPng), Border Gateway Protocol version 4 plus (BGP4+), and Intermediate System-to-Intermediate System (IS-IS) over IPv6. This supports the deployment of large-scale IPv6 networks in the future.
644
加载失败
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
TOP
