RG-AP6920-D ไร้สาย - 1
RG-AP6920-D ไร้สาย - 2
RG-AP6920-D ไร้สาย - 3
RG-AP6920-D ไร้สาย - 4
RG-AP6920-D ไร้สาย - 5
RG-AP6920-D ไร้สาย - 6
RG-AP6920-D, Wi-Fi 7 Dual-Radio 3.570 Gbps Outdoor Access Point
Suitable for outdoor scenarios across various sectors covering higher education, government, general education, finance, and business.
  • Seamless Upgrade to Wi-Fi 7
  • Directional Coverage with Strong Signal
  • Digital Twin Network, Improving Network O&M Efficiency by 30%
Key Specification View More
RG-AP6920-D, Reliable and Stable Outdoor Wi-Fi 7
The Ruijie RG-AP6920-D is a next-generation outdoor wireless access point (AP) in compliance with Wi-Fi 7 (802.11be). It features a dual-radio design, a peak rate of 3.570 Gbps, an IP68 rated enclosure, and built-in directional antennas. These characteristics make it suitable for outdoor scenarios in various sectors covering education, government, finance, and business.
IP68 protection: dustproof and waterproof
Wider temperature range: -40°C to +55°C, adaptable to various regions
6 kV lightning protection: ensures stable operation during lightning
20% higher peak throughput
28 dBm transmission power for robust signal beams, ideal for outdoor scenarios like streets and security monitoring networks.
The AP supports intelligent O&M functions, including visualized fault locating, local network optimization, and service network optimization.
RG-AP6920-D
Channel:
2 spatial streams
Channel:
Channel:
● Radio 1 – 2.4 GHz: 7.3 Mbps to 0.574 Gbps (MCS0 to MCS11)
802.11be
Channel:
● Aggregate MAC Service Data Unit (A-MSDU)
● 2.4 GHz: two built-in directional antennas, with peak antenna gain of 9 dBi. Horizontal lobe angle of 35° and vertical lobe angle of 65°.
● 5 GHz: two built-in directional antennas, with peak antenna gain of 15 dBi. Horizontal lobe angle of 15° and vertical lobe angle of 30°.
● One built-in antenna, with peak antenna gain of 4 dBi.
1 x 100/1000/2.5GBASE-T port
1 x Bluetooth 5.3
1 x system status LED
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Three single-color signal strength LEDs
● Whether bridging is enabled
Dimensions (W x H x D)
Main unit: 251 mm x 173 mm x 56 mm (9.88 in. x 6.81 in. x 2.20 in.)
Shipping: 405 mm x 325 mm x 323 mm (15.94 in. x 12.80 in. x 12.72 in.)
Main unit: 1.45 kg (3.20 lbs)
Mounting plate assembly: 0.35 kg (0.77 lbs)
Mounting bracket: 0.15 kg (0.33 lbs)
Shipping: 2.75kg (6.06 lbs)
Wall/Pole-mount
● 48 V DC/0.35 A power input over DC connector
Maximum power consumption: 14.95 W
● DC power: 30 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
● 802.3at (PoE+): 30 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
● 802.3af (PoE): 15.4 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, The maximum channel widths in the 2.4 GHz and 5 GHz frequency bands are reduced to 20 MHz and 40 MHz. The data rate of the RJ45 port is limited to 1 Gbps.
● Idle mode: 7.8 W
Operating temperature: –40°C to +55°C (–40°F to 131°F)
512 MB, 256 MB flash
● Maximum transmit power: 28 dBm (630.96 mW)
Wi-Fi Radio Performance
RG-AP6920-D
25 dBm
–96 dBm
24 dBm
–84 dBm
24 dBm
–78 dBm
25 dBm
–95 dBm
21 dBm
–75 dBm
25 dBm
21 dBm
–73 dBm
25 dBm
–96 dBm
–67 dBm
25 dBm
–93 dBm
–64 dBm
2.4 GHz, 802.11be (EHT40)
25 dBm
–92 dBm
–63 dBm
25 dBm
–96 dBm
24 dBm
–87 dBm
24 dBm
–78 dBm
25 dBm
–96 dBm
21 dBm
–76 dBm
25 dBm
–92 dBm
21 dBm
–73 dBm
25 dBm
–97 dBm
21 dBm
–74 dBm
25 dBm
–94 dBm
–69 dBm
25 dBm
–92 dBm
19 dBm
–66 dBm
25 dBm
–97 dBm
–68 dBm
25 dBm
–94 dBm
–63 dBm
25 dBm
19 dBm
–67 dBm
–61 dBm
5 GHz, 802.11ax (HE160)
25 dBm
–88 dBm
19 dBm
–64 dBm
–58 dBm
5 GHz, 802.11be (EHT80)
25 dBm
19 dBm
–67 dBm
–62 dBm
MCS13
–56 dBm
5 GHz, 802.11be (EHT160)
25 dBm
–88 dBm
19 dBm
–65 dBm
–58 dBm
MCS13
–55 dBm
The following table lists the power consumption and operating status of the RG-AP6920-D.
Power Supply Mode
PoE Input (802.3af-Compliant)
PoE+ Input (802.3at-Compliant)
DC Power Input
Output Power Consumption
15.4 W
30 W
30 W
Radio 1 (2.4 GHz)
2x2 MIMO, 20 MHz
2x2 MIMO, 40 MHz
2x2 MIMO, 40 MHz
Radio 2 (5 GHz)
2x2 MIMO, 40 MHz
2x2 MIMO, 160 MHz
2x2 MIMO, 160 MHz
LAN Port
Bluetooth Low Energy (BLE)
RG-AP6920-D
RGOS11.9(6)W3B19 or later
Maximum number of WLAN IDs
Mobile unit (MU) location
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES), and WPA3
Dynamic Policy
MAC address table size: 1,024
Jumbo frame length: 1,518
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Fault detection and alarming
RG-AP6920-D
EN 55032, EN 55035, EN IEC 61000-3-2, EN 61000-3-3, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, EN IEC 62311, FCC Part 15, IEC 62368-1, EN 62368-1, EN 60950-22
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP6920-D] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijienetworks.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP6920-D] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijienetworks.com/.
  • Order an RG-AP6920-D outdoor access point.
  • If the uplink switch supports PoE and complies with IEEE 802.3af/at standard, connect the uplink port of the RG-AP6920-D to the PoE switch to power the RG-AP6920-D.
  • If the uplink switch does not support PoE, purchase a DC power supply from a third-party vendor to provide 48 V/0.35 A power input over the DC connector on the RG-AP6920-D.
  • To use the SFP port, select a proper optical transceiver as required.
    RG-AP6920-D
    Used with the RG-WS6512 or RG-WS6008 access controller
    Wi-Fi 7 dual-radio outdoor access point
    ● Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 0.688 Gbps
    The AP consumes one license of an AC.
    Fat/Fit/Cloud mode switching. IEEE 802.3af/at-compliant (PoE/PoE+) and DC power supply
    Note: The DC power supply needs to be purchased separately, and the output voltage/current must be 48 V/0.35 A.
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
