RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 1
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 2
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 3
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 4
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 5
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 6
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 7
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 8
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 9
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 10
RG-S6150-24VS8CQ-X Thiết bị chuyển mạch - 11
RG-S6150-24VS8CQ-X 24-Port 10GE All-Optical Layer 3 Managed Core & Aggregation Switch, 100G Uplink
  • Rich port types, 24 x 10G optical ports, and 8 x 40G/100G optical ports for uplink
  • Paired with INC for simplified and efficient O&M
Thông số chi tiết chính View More
Fixed port
24 x 10GE/25GE (license required for 25G*) SFP28 ports
8 x 40GE/100GE QSFP28 ports
1 x MGMT port, 1 x console port, and 1 x USB 2.0 port
2.8Tbps
Cooling mode
Fan cooling
270 W
Link aggregation
0°C to 45°C (32°F to 113°F)
Layer 3 10GE All-Optical Core & Aggregation Switch
RG-S6150-24VS8CQ-X
Core switch for small and medium-sized networks, or aggregation switch for large networks, with 24 x 25G service ports and eight 100G uplink ports
Flexible access capabilities, which fully cater to the requirements of high-performance networks, supporting smooth evolution to 25G campus networks
and Network Connectivity
Optical Port Fault Isolation
Guaranteed Data Transmission
Abundant Multicast Protocols
Enhanced Network Robustness
achieving automatic O&M.
Hareware Specifications
RG-S6150-24VS8CQ-X
RG-S6150-48VS8CQ-X
Interface Specifications
Fixed port
48 x 10GE/25GE (license required for 25G*) SFP28 ports
4 x fan modules
3+1 redundancy, at least three fan modules required for the system
Fan speed regulating and fault alarming
2 x hot-swappable power modules
System switching capacity
2.8 Tbps
4 Tbps
Number of global MAC addresses: 128,000 (default)
Number of static MAC addresses: 10,000
96,000 (default)
96,000 (default)
ND table size
80,000 (default)
80,000 (default)
350,000 (default)
350,000 (default)
65,000 (default)
65,000 (default)
Ingress: 28,000
Egress:4,000
Number of IGMP groups
Number of MLD groups
Number of VRFs
Weight (four fan modules and two power modules at full load)
10 kg (22.05 lbs)
10 kg (22.05 lbs)
CPU and Storage
2.2 GHz quad-core processor
Storage
DDR4 4 GB
8 GB flash memory
DDR4 4 GB
8 GB flash memory
Data packet buffer
35 MB
35 MB
Power and Consumption
270 W
300 W
PA550I II-F:
90–264 V AC or 100–240 VAC, 550 W
PA550I II-F:
Rated input voltage
AC input: 100 V AC to 240 V AC
Frequency: 50/60 Hz
HVDC input: 240 V DC
Maximum input voltage
AC input: 90 V AC to 264 V AC
HVDC input: 192 V DC to 288 V DC
> 200,000 hours
> 200,000 hours
Primary airflow
Front-to-rear airflow
Maximum operating altitude
5000 m (16404.20 ft.)
Interface surge protection
Telecom port: 4 kV (MGMT port)
Software Specifications
RG-S6150-X Series
Basic QinQ and selective QinQ
Non blocking
GRE tunnel
IP routing
SVI: 4k supported
MCE
Stateless auto configuration
IPv4/IPv6 VRF
IPv4/IPv6 PBR
IGMPv1/v2/v3 and IGMP proxy
MLD snooping
ACL80 and IPv6 ACL
ACL redirection
Multi-AAA
RADIUS and TACAS+
Global IP-MAC binding
MAB authentication
SSH
Loose and strict RPF
uRPF ignoring default routes
IPv4 VRRP v2/v3 and IPv6 VRRP
Hot swapping of fan modules
NTP an SNTP
FTP and TFTP
SNMP v1/v2/c3
RMON (1, 2, 4, 9)
Ruijie Could-based management
LAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv4
EVPN VXLAN
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
The switch, expansion module, power module, and other components can be ordered as needed. Before ordering an expansion module or power module, please contact the online customer service personnel for the latest support information about the module.
RG-S6150-24VS8CQ-X
24 x 10G/25G SFP28 ports (default: 10G; the rate can be increased to 25G with a license.)
8 x 40G/100G QSFP28 ports
4 fan modules
2 power supply module slots
At least one RG-PA550I II-F power supply module needs to be purchased.
RG-S6150-48VS8CQ-X
48 x 10G/25G SFP28 ports (default: 10G; the rate can be increased to 25G with a license.)
4 fan modules
RG-PA550I II-F
550 W AC power supply module
1000BASE-GT mini GBIC module
10G LC interface module (62.5/125 μm: 33 m; 50/125 μm: 66 m; 300-meter transmission at modal bandwidth of 2000 MHz·km), applicable to SFP+ ports
10G LC interface module (1310 nm), 10 km, applicable to SFP+ ports
10G LC interface module (1550 nm), 40 km, applicable to SFP+ ports
10G SFP+ fiber-optic cable, 1 m, including one cable and two interface modules
10G SFP+ fiber-optic cable, 3 m, including one cable and two interface modules
10G SFP+ fiber-optic cable, 5 m, including one cable and two interface modules
25G SFP28 module, MMF, max cabling distance: 100 m
VG-SFP-SR-MM1310
25G SFP28 module, SMF, max cabling distance: 10 km
VG-SFP-AOC5M
25G Base SFP+ fiber-optic cable (including modules on both ends), 5 m
40G SR multi-mode fiber module, applicable to QSFP+ ports (OM3/OM4 MPO connector, 8 core, 850-nm wave length, max cabling distance: 100 m(OM3), 150 m(OM4))
40G-QSFP-LR4 SM1310
40G LR single-mode fiber module, applicable to QSFP+ ports, max cabling distance:10 km (LC interface, 2 core, 1310-nm wave length)
40G QSFP+ fiber-optic cable, 5 m, including one cable and two interface modules
40G-AOC-10M
40G QSFP+ fiber-optic cable, 10 m, including one cable and two interface modules
100G SR fiber module, QSFP28 encapsulation, MPO connector, 850-nm wave length, max cabling distance: 100 m(OM4), 70 m (OM3)
100G LR fiber module, QSFP28 encapsulation, LC interface, 1310-nm wave length, max cabling distance: 10 km (SMF)
100G-AOC-1M
100G QSFP28 fiber-optic cable, 1 m, including one cable and two interface modules
100G QSFP28 fiber-optic cable, 5 m, including one cable and two interface modules
100G QSFP28 fiber-optic cable, 10 m, including one cable and two interface modules
Are 25G ports of the RG-S6150-X series switch backward compatible with 10G?
Yes, the 25G SFP28 ports are backward compatible with 10G, and the 100G QSFP28 ports are backward compatible with 40G.
80
Does the RG-S6150-X series support VXLAN?
Yes.
79
What are the operation and maintenance management modes supported by an RG-S6150-X series switch?
This series supports SNMP, RMON, Syslog, USB log backup and other functions for routine maintenance, and supports CLI, Eweb, Telnet and other modes for device management. With the INC controller, fast onboarding, optical link operation and maintenance, and zero-touch replacement are supported for efficient operation and maintenance. This series also supports gRPC-based Telemetry technology, which can periodically collect CPU, memory and other information to achieve automatic management.
76
加载失败
TOP
