Key Specification View More
Ruijie Wi-Fi 5 Indoor AP
RG-AP720-L
2.4 GHz/5 GHz Dual Radios
PoE and DC Power Input
Ceiling Mounting and Wall Mounting
WIS-based Cloud Management
Dual Radios, Combined Rate Up to 1.167 Gbps
This AP provides both a stable 5 GHz band, and a wide-coverage 2.4 GHz band. Dual radios ensure stable connectivity for more STAs.
Auto Configuration, Simplified Provisioning, Easy Deployment
You do not need to pre-configure this AP before installation. Once connected to a Ruijie wireless AC, this AP can obtain configurations from the AC to complete provisioning, thus greatly reducing the implementation and maintenance workload.
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
RG-AP720-L
194 mm x 194 mm x 37 mm (7.64 in x 7.64 in x 1.46 in)
460 mm x 360 mm x 242 mm (18.11 in x 14.17 in x 9.53 in)
Main unit: 0.42 kg (0.93 lbs)
0.87 kg (1.92 lbs)
Wall/Ceiling-mount (a mounting bracket is delivered with the main unit)
RG-AP720-L
 Radio 1: 2.4 GHz, two spatial streams, 2x2 MIMO
 Radio 2: 5 GHz, two spatial streams, 2x2 MU-MIMO
Operating frequencies
Radio 1, 802.11b/g/n:
 2.400 GHz to 2.4835 GHz, ISM
Radio 2, 802.11a/n/ac:
 5.150 GHz to 5.250 GHz, U-NII-1
 5.250 GHz to 5.350 GHz, U-NII-2A
 5.470 GHz to 5.725 GHz, U-NII-2C
 5.725 GHz to 5.850 GHz, U-NII-3/ISM
Data rates
Combined peak data rate: 1.167 Gbps
2.4 GHz radio
 Two spatial stream Single User (SU) MIMO for up to 300 Mbps wireless data rate to individual 2SS HT40 802.11n client devices (max.)
 Two spatial stream Single User (SU) MIMO for up to 144.4 Mbps wireless data rate to individual 2SS HT20 802.11n client devices (typical)
5 GHz radio
 Two spatial stream Single User (SU) MIMO for up to 867 Mbps wireless data rate to individual 2SS HT80 802.11ac client devices (typical)
Data rate set
2.4 GHz radio
 802.11b: 1, 2, 5.5, 11
 802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, 54
 802.11n: 6.5 to 300 (MCS0 to MCS15, HT20 to HT40)
5 GHz radio
 802.11a: 6, 9, 12, 18, 24, 36, 48, 54
 802.11ac: 6.5 to 867 (MCS0 to MCS9, NSS = 1 to 2, VHT20 to VHT80)
Packet aggregation
802.11n/ac: A-MPDU and A-MSDU
Built-in omnidirectional antenna (two 2.4 GHz antennas and two 5 GHz antennas)
Max. antenna gain
4.3 dBi in 2.4 GHz and 5.7 dBi in 5 GHz
The downtilt angle for the maximum gain is roughly 30 degrees.
With reference to the pattern of each antenna of the MIMO radios, the maximum gain of the effective per-antenna pattern is 3.6 dBi in the 2.4 GHz radio and 4.0 dBi in the 5 GHz radio.
Max. transmit power
Thailand
Radio technologies
802.11b: BPSK, QPSK, CCK
RG-AP720-L
1 Mbps
–89dBm
–88 dBm
11 Mbps
6 Mbps
24 Mbps
36 Mbps
21 dBm
–76 dBm
54 Mbps
19 dBm
–70 dBm
21 dBm
–83 dBm
19 dBm
–65 dBm
21 dBm
–62 dBm
6 Mbps
24 Mbps
36 Mbps
21 dBm
–76 dBm
54 Mbps
19 dBm
–70 dBm
–83 dBm
–65 dBm
19 dBm
–62 dBm
17 dBm
–57 dBm
19 dBm
19 dBm
–76 dBm
–51 dBm
–83 dBm
–65 dBm
19 dBm
–62 dBm
RG-AP720-L
1 x 10/100/1000Base-T RJ45 Ethernet port with auto-negotiation
 Compliance with IEEE 802.3af standard (PoE)
 Auto MDI/MDIX crossover
 PoE-PD: 54 V DC (nominal) 802.3af/at/bt (Class 3 or higher)
 802.3az EEE
 Press the button for shorter than 2 seconds. Then the device restarts.
 Press the button for longer than 3 seconds. Then the device restores to factory settings.
RG-AP720-L
 12 V DC/1.5 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power adapter needs to be purchased separately.
 PoE input over LAN 1: The power source equipment (PSE) complies with IEEE 802.3af standard (PoE).
 If both DC power and PoE are available, DC power is preferred.
Max power consumption: 12.95 W
 DC powered: 12.95 W
 PoE+ powered (802.3at): 12.95 W
 PoE++ powered (802.3bt): 12.95 W
 Idle mode: 6 W
RG-AP720-L
Note: At an altitude between 3,000 m (9,843 ft) and 5,000 m (16,404 ft), every time the altitude increases by 220 m (722 ft), the maximum temperature decreases by 1°C (1.8°F).
Environment standard
Storage and operating environment: NEBS GR-63-CORE_Issue3_2006 GB/T 2423.6-1995
RG-AP720-L
EN 301 489-3
EN 301 489-17
EN 300 328
FCC Part 15
EN IEC 62311
EN 62368-1
Applicable Software Version
RG-AP720-L
RGOS 11.1(9)B1P30 or higher
RG-AP720-L
Recommended max number of active devices per AP
Max number of associated clients
256
Note
Max. number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
RG-AP720-L
PSK, web, 802.1X and MSCHAPv2 authentication
QR code-based guest authentication (used with the RG-WS series wireless access controller)
Data encryption: WPA (TKIP), WPA-PSK, WPA2 (AES), WEP (64/128-bit)
Routing and Switching
RG-AP720-L
IP service
Static IPv4 address
IPv4 DHCP client
FTP ALG and DNS ALG
IPv6 basics
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 Ping, IPv6 Tracert
RG-AP720-L
Fault inspection and alarm
Web-based management (Eweb)
Telnet, SNMP, and TFTP-based management
Fat/Fit/Cloud mode switchover
RG-AP720-L
Data rate of up to 1,167 Mbps
Compliance with IEEE 802.11a/b/g/n and 802.11ac Wave2 standards
One uplink electrical port
