RG-RSR830-P, 10-Port Mobile Router
The router integrates routing, switching, wireless, and other network functions, supports PoE, and is applicable to customers with multiple branches, such as retail stores, chain stores, logistics, and offices.
WAN: 2 x electrical ports LAN: 8 x GE electrical ports (LAN/WAN switchable) PoE Wi-Fi 6
RG-RSR830WWAN: 2 x GE electrical ports LAN: 8 x GE electrical ports (LAN/WAN switchable) Wi-Fi 6
RG-RSR830-PWAN: 2 x GE electrical ports LAN: 8 x GE electrical ports (LAN/WAN switchable) PoE
RG-RSR830WAN: 2 x GE electrical ports LAN: 8 x GE electrical ports (LAN/WAN switchable)
Hardware Specifications |
RG-RSR830 |
RG-RSR830W |
RG-RSR830-P |
RG-RSR830W-P |
Forwarding performance |
0.5 Mpps |
0.5 Mpps |
0.5 Mpps |
0.5 Mpps |
Fixed service port |
Uplink WAN ports: 2 x 10/100/1000BASE-T ports Downlink LAN ports: 8 x 10/100/1000BASE-T ports, which can be switched to WAN ports
Uplink WAN ports: 2 x 10/100/1000BASE-T ports Downlink LAN ports: 8 x 10/100/1000BASE-T ports, which can be switched to WAN ports |
Uplink WAN ports: 2 x 10/100/1000BASE-T ports Downlink LAN ports: 8 x 10/100/1000BASE-T ports, which can be switched to WAN ports LAN ports 2 to 9 support PoE/PoE+ |
Fixed management port |
1 x RJ45 console port |
USB |
1 x USB 2.0 port, for connecting to the USB flash drive |
Memory |
2 GB |
2 GB |
2 GB |
2 GB |
Flash Memory |
4 GB |
4 GB |
4 GB |
4 GB |
VPN performance (256- bit AES encryption) |
400 Mbps |
400 Mbps |
400 Mbps |
400 Mbps |
Number of IPsec VPN Tunnels |
100 |
100 |
100 |
100 |
Expansion Module |
● SIC-LTE-GS LTE card (Cat-6, 2 x SIM, active-standby) ● SIC-LTE-GD LTE card (Cat-6, 2 x SIM, active-active) ● SIC-5G-G 5G NR in global bands single card, small plug-in card ● SIC-2SFP Expansion gigabit optical module plug-in card |
Wi-Fi Port |
N/A |
802.11 b/g/n/ac/ax |
N/A |
Unit Dimensions (W x D x H) |
260 mm × 170 mm × 38 mm (10.24 in. x 6.70 in. x 1.50 in.) |
Without external antennas: 278 mm x 171 mm x 38 mm (10.94 in. x 6.73 in. x 1.50 in.) With external antennas: 350 mm x 171 mm x 88 mm (13.78 in. x 6.73 in. x 3.46 in.) |
Without external antennas: 278 mm x 171 mm x 38 mm (10.94 in. X 6.73 in. X 1.50 in.) With external antennas: 350 mm x 171 mm x 88 mm (13.78 in. x 6.73 in. x 3.46 in.) |
Unit weight |
0.95 kg (2.09 lbs) |
1.04 kg (2.29 lbs) |
1.05 kg (2.31 lbs) |
1.14 kg (2.51 lbs) |
Maximum Power Consumption |
36 W (including module power) |
150 W (including PoE power and module power) |
Input power supply |
36 W Power Adapter: ● Input: 100 V AC to 240 V AC, 50 Hz to 60 Hz, 0.9 A max. ● Output: 12 V DC, 3 A max, 36 W |
150 W Power Adapter: ● Input: 100 V AC to 240 V AC, 50 Hz to 60 Hz, 2 A max. ● Output: 56 V DC, 2.68 A, 150 W |
Recommended number of user |
300 |
300 |
300 |
300 |
External Power Supply |
N/A |
N/A |
Each port provides up to 30 W of power. The device provides up to 110 W of power. |
Temperature |
Operating temperature: 0°C to 45°C (32°F to 113°F) Storage temperature: –40°C to +70°C (–40°F to +158°F) |
Humidity |
Altitude |
Operating altitude: –500 m to +4000 m (–1640.42 ft. to +13123.36 ft.) Storage altitude: –500 m to +5000 m (–1640.42 ft. to +16404.20 ft.) |
IP rating |
IP30 |
IP30 |
IP30 |
IP30 |
Software Specifications |
RG- RSR830 Series
Ethernet |
Jumbo frame forwarding (max. size: 1974) Frame format: Ethernet II Change of the MTUs (link MTU and IP MTU) in the forwarding plane Forcibly converting the 1000M optical port into the electrical port in auto-negotiation mode (100M/1000M) LAN/WAN switching Interface auto-negotiation factor Interface WAN/LAN mode switching |
ACL and QoS |
IP standard ACL IP extended ACL Association with the egress ACL based on a Layer 3 interface (SVI/routed port/L3 AP) HQoS: DSCP/IP-PRE/COS HQoS: PQ\WFQ\LPQ methods of congestion scheduling |
IPv4 application protocol features |
DHCP client Option 43/52/138 |
DHCP server Option 138 Option 43 Option 82 Large address pool Alarm (Syslog) |
Configuring DHCP snooping in a VLAN Configuring DHCP snooping on a logical interface (including the physical interface and aggregate interface) Trusted interface |
DNS DNS client |
FTP client |
NTP client NTP server TFTP client TFTP server |
IPv6 application protocol features |
DHCPv6 client Option 18 Option 37 |
DHCPv6 server Option 52 DHCPv6 Snooping ND Snooping |
FTP server TFTP server TFTP client NTP server NTP client |
Layer 2 features |
LLDP |
Layer 2 features |
MAC address filter Interface-based MAC address learning Static MAC address Global MAC address learning Enforcing deletion of a MAC address using a command MAC address aging time Port based VLAN Spanning Tree Protocol |
Layer 3 features |
Proxy ARP ARP entry aging |
Ping Traceroute |
Layer 3 features |
GRE tunnel PBR/ACL/QoS/NAT for IPv4 & IPv6 services on a GRE interface Inner and outer VRF configuration |
IPv4 & IPv6 VRF |
BGP4/BGP4+ IS-IS v4/v6 OSPF v2/v3 RIP v1/v2 PBR |
VAG |
Intelligent routing Load balancing Active/Standby scheduling for undefined applications Controller management Disaster recovery |
WLAN features |
WLAN services: SSID configuration SSID-based VLAN configuration UTF8 SSID |
Wireless security: WPA3 User isolation: Layer 2 isolation |
WLAN features |
RF resources: Channel configuration Channel width configuration Power configuration Automatic RF optimization (channel, channel width) WMM configuration 802.11 b/g/n/ac/ax |
Security features |
AAA and web authentication |
EXEC authorization, RADIUS, interworking with the SAM/SMP/ACS server, and specifying the source IP address (through the source interface) |
Account allocation by user and login authentication (password, none) |
Encrypted transmission and storage of static passwords, password lifetime check, and reuse limitation |
Security features |
Application identification,url Filtering, IDS/IPS, blacklist and whitelist |
CPP and NFPP |
Management features |
gRPC framework |
NETCONF |
TACACS |
SNMP v1/v2/v3 |
SSH |
Syslog |
IPv4 supported by the Telnet server |
HTTP server V1.1 HTTPS server Out-of-the-box web management |
Eweb 2.0 |
Hostname configuration YANG model |
USB-based deployment |
Obtaining device information through gRPC |
Model |
Description |
RG-RSR830 |
2x GE WAN ports, 8 x GE RJ45 LAN ports |
RG-RSR830W |
2x GE WAN ports, 8 x GE RJ45 LAN ports, supporting 802.11 b/g/n/ac/ax WIFI |
RG-RSR830-P |
2x GE WAN ports, 8 x GE RJ45 LAN ports, supporting PoE power supply, and maximum PoE output power of 110 W |
RG-RSR830W-P |
2x GE WAN ports, 8 x GE RJ45 LAN ports, supporting 802.11 b/g/n/ac/ax WIFI, supporting PoE power supply, and maximum PoE output power of 110 W |
Expansion Module
Model |
Description |
SIC-5G-G |
5G NR small-sized card, supporting dual SIM single standby, 4 x SMA-K antenna interfaces |
SIC-LTE-GD |
4G LTE small-sized card, supporting dual SIM dual standby and global D band (double) |
SIC-LTE-GS |
4G LTE small-sized card, supporting dual SIM single standby and global S band (single) |
SIC-2SFP |
GE expansion card of optical modules, 2 x 1GE SFP ports |
Contacte-nos
