RG-RSR30-XA-24 24-Port Multi-service Fixed Aggregation Router
Recommended as an egress router for networks of public sector commission offices, government at the district and county levels.
  • Self-developed next-generation RGOS12.X and innovative architecture, providing high performance and scalability and enabling non-blocking concurrent services
24-Port High-Density 10GE Fixed Aggregation Router
RG-RSR30-XA-24
The router provides multiple WAN ports and integrates routing, security, wireless and other functions. The router is recommended as an egress router for networks of public sector commission offices, government at the district and county levels, and small and medium-sized parks, and as an aggregation router for networks of small and medium-sized enterprises.
The next-generation HSIC expansion module is supported and rich expansion modules are provided to meet various combination requirements.
Applications
4G/5G supported
Next-Generation Operating System RGOS and Innovative Architecture,Providing High-Performance and Scalability and Enabling Non-Blocking Concurrent Services
The innovative architecture combines the CPU, network chip, and service-specific chip to accelerate hardware performance, while enabling unified business scheduling. The independent operation of each business component ensures that a single business malfunction will not affect the normal operation of the entire machine.
Software-Level Dual-Boot
RG-RSR30-XA-24
Interface Specifications
Fixed WAN port
8 x 10GE optical ports
16 x GE electrical ports
Power modules
2 redundant power modules (hot swapping)
Fixed management ports
1 x console port, 1 x USB 2.0 port
Expansion slot
10 Gbps
300,000
2,048
300,000
Number of IGMP groups
Number of MLD groups
Ingress: 16,000
Egress: 16,000
440 mm x 420 mm x 44 mm (17.32 inch. x 16.56 in. x 1.73 in.), 1 RU
Weight (full configuration)
< 7.8 kg (17.20 lbs) (excluding packaging)
Power and Consumption
< 150 W
RG-PA150IB-F: 150 W @ 10 A power cord
Rated input voltage
RG-PA150IB-F: 100 V AC to 240 V AC, 50 Hz to 60 Hz
Maximum input voltage
RG-PA150IB-F: 90 V AC to 264 V AC, 47Hz~63Hz
> 100,000 hours
0°C to 50°C (32°F to 122°F)
5% to 95% RH (non-condensing)
Interface surge protection
6 kV
Operating altitude
0–3000 m (0–9,842.52 ft.)
RG-RSR30-XA Series
Jumbo frame length: 1578 bytes
FTP, TFTP, FTPv6, and TFTPv6
NTP, SNTP, and NTPv6
NAT
ND
ND and ND snooping
IPv6 GRE tunnel
BGP and BGP4+
Routing policies
BGP4, BGP4+, and MP-BGP
IGMP v1/v2/v3
Static multicast routing
Basic MPLS functions
MPLS forwarding
L3VPN
LSP
LDP
IPv6 ACLs
Applying ACLs to interfaces
MPLS QoS
Attack defense
Password security
RNFP
FPM
PKI
VPDN
Hot swapping
SPAN and ERSPAN
IPFIX
Interface
Ethernet interface, E1/CE1 interface, and 4G interface
RG-RSR30-XA-24
RG-RSR30-XA-24 chassis, 8 x 10GE optical WAN ports and 16 x GE electrical WAN ports, 4 x Expansion slots, 1 x USB 2.0 port, 1 x console port
Power Modules
Line Card
HSIC-2E1/CE1
2-port E1/CE1 module (the cable needs to be purchased separately)
HSIC-4G-LTE-G
1-port full-mode 4G and encryption module (the antenna needs to be purchased separately)
*HSIC-5G-NR
1-port full-mode 5G and encryption module (the antenna needs to be purchased separately)
*HSIC-1POS-STM1
1-port OC-3c/STM-1c POS interface card (the optical module needs to be purchased separately)
How many concurrent terminals are allowed?
The number of concurrent terminals of a router is a common performance indicator used when configuring the router as an egress router. RG-RSR30-XA-24 can support a maximum of 1,000 concurrent terminals after being configured with egress applications. For more information, visit the official website and consult pre-sales service on the right side of the web page.
191
What is the function of the FUNC button on the device?
The FUNC button on the device can be used to import configuration files through a USB drive, allowing for simple configuration and software upgrade without complicated CLI operations, thus improving deployment efficiency.
657
Is IPv6 supported by this router?
Yes. This router supports IPv4/IPv6 dual stack and multiple IPv6 routing technologies such as static routing, equal-cost multi-path routing, policy-based routing, Open Shortest Path First version 3 (OSPFv3), Routing Information Protocol Next Generation (RIPng), Border Gateway Protocol version 4 plus (BGP4+), and Intermediate System-to-Intermediate System (IS-IS) over IPv6. This supports the deployment of large-scale IPv6 networks in the future.
644
加载失败
TOP
